just lowered the car and not happy with the height
  • Thread starter Thread starter sonic281
  • Start date Start date Jan 12, 2012
1 of 2 Next Last
sonic281
79
glendale az
Jan 12, 2012
  • Jan 12, 2012
got the sve springs from lrs and it barely did a little drop to the car. Do you think i should remove the isolators ill put some pics up in a bit
D
Deleted member 38176
Jan 12, 2012
  • Jan 12, 2012
Removing the isolators won't make much difference. Sounds like you didn't do your homework before pulling the trigger.
joshjwc9
1,095
17
39
Palm Harbor, FL
Jan 12, 2012
  • Jan 12, 2012
If they are brand new they will settle somewhat. Be patient before you rip the rears out to remove the isolaters. Also, be ready to replace your stock shocks and struts if you haven't replaced them already. The increased spring rate will reduce shelf life of the OEM's due to the stock valving which is engineered for the 4x4 springs.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jan 12, 2012
  • Jan 12, 2012
Iso will help a tad but you wont see the full drop of the springs until after about 30 days...and as nightfire stated, if you were looking for a significant drop a little more thread searching may have helped
sonic281
79
glendale az
Jan 13, 2012
  • Jan 13, 2012
They were a christmas gift! What you expect me to give them back and say they suck. Dont insult me on saying I didnt do my homework.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jan 13, 2012
  • Jan 13, 2012
nobody was insulting you and how were we supposed to know you didn't buy them
anyway, wait it out...it usually takes about a month for the springs to fully settle and reach their real ride height.. when i first put my sportlines in i was pissed off so bad because they only lowered the car 1/4". then as the weeks went by i kept noticing the stance getting lower and lower then i finally liked it..
if after about a month the car still doesn't sit how you want pull the isos. i got about another 1/4 or more out of my drop after doing so.. every car is different so you may get more or you may get less..1/4" doesn't sound like a whole lot but you can definitely tell the difference. Good luck and post some pics
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jan 13, 2012
  • Jan 13, 2012
should have done your homework
N8Dogg98
3,872
238
184
MN
Jan 13, 2012
  • Jan 13, 2012
I installed poly iso's with my Pro-kit and they added about 1/2" to the total ride height... once I removed them it looked much better. Stock ISO's you're looking at about 1/4"... the springs should settle some after they've been on for a couple weeks, too
Oh and you clearly didn't do your homework
D
Jan 13, 2012
  • Jan 13, 2012
Nothing was meant as an insult. If I had received some springs as a gift, I would have researched what kind of drop they offered, along with other specs. If I found out that they weren't exactly what I was looking for, I'd try to sell them and use that money to purchase the springs that I want or have them cut PRIOR to installing them
Like others have stated, remove the iso's and allow them to settle. If you're still not satisfied, have them cut.
sonic281
79
glendale az
Jan 13, 2012
#10
  • Jan 13, 2012
  • #10
I did reserch the drop height and looked at customer pictures and they looked good. So I did do my homework. Would be appreciated if everyone would be mature and stop posting that i clearly didnt do my homework! Thought this site was for advice which I got from a couple of you and others making pointless remarks.
BurningRubber
1,865
24
58
Jan 13, 2012
#11
  • Jan 13, 2012
  • #11
Everyone's just messing with ya man, don't take it personally.
As stated, they'll settle a little. If you're not happy with them at that point, pull the iso's. It's easy and if you wrap the coils where they sit on their perches with electrical tape, they won't make noise. Wrapping it 3-4 layers is plenty. You'll notice a little bit of difference in height, and it may be just what you're looking for.
TeufelGt
164
San Antonio, Tx
Jan 15, 2012
#12
  • Jan 15, 2012
  • #12
+1 on the settling. My springs took about a month or so to reach full drop. They literally dropped about a full inch man. Im sure over the next few weeks they'll drop nicely. and if not you can pull the isos out and get a little more out of then.
TylerByers18
110
Grand Prairie, TX
Jan 16, 2012
#13
  • Jan 16, 2012
  • #13
sell them and get some h&r springs and take out the iso's or get some coilovers
N8Dogg98
3,872
238
184
MN
Jan 16, 2012
#14
  • Jan 16, 2012
  • #14
Yea... like I said, do your homework and all will be well
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Jan 16, 2012
#15
  • Jan 16, 2012
  • #15
someone didnt do my homework
fiveoho
1,958
TN
Jan 17, 2012
#16
  • Jan 17, 2012
  • #16
don't let some of these guys get to you buddy, most are just messing with you. the others....well, just overlook them. a handful concentrate more on being a smart A rather than trying to help.
dont get too discouraged yet. run them for a few miles and see if they settle any. they are already installed so even if you take them out now, they are still "used" . a few hundred miles won't hurt anything. worst case if they don't drop, throw them on craigslist. mustang parts sell fast on there usually. use the cash and get some H&R's. removing your iso's may help a little. i removed my top and bottom isolators and it gave me about a 1/2" additional drop ( those were energy suspension isolators tho, thicker than stock rubber ones i believe ) .
good luck. hopefully you will see more of a drop with some time.
Admin Dude
Jan 4, 1985
43,158
21,330
234
Box behind Walmart
Jan 17, 2012
#17
  • Jan 17, 2012
  • #17
The dog ate my homework.
F
fullrearview
65
#18
  • Jan 17, 2012
  • #18
It's the interwebz... People are going to say things like they have no filter. You are thousands of miles away and there are no consequences. SO.... You can keep feeding the trolls, or you can ignore it.
sonic281
79
glendale az
Jan 17, 2012
#19
  • Jan 17, 2012
  • #19
thanks to you couple guys who did give me helpfull advice. appreciate ill put a pic up of the car let me know what you think
T
turbogt
723
Montana
Jan 17, 2012
#20
  • Jan 17, 2012
  • #20
Get x2 ballpoints. . It will lower the front another 1/2"
1 of 2 Next Last
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Monday at 3:10 PM
Creomod
