Just lowered the GT, now the back sits wayyy to low
patrickg302
21
I've got a 1996 GT. Today I installed all new shocks, struts, tie roads, and lowering springs. What I've got is the H&R lowering springs from american muscle and Gabriel G-Force Struts and shocks. The front sits perfect, but the back wheel wells are touching the wheels. I've got the pigtails of the springs facing the drivers side as this guide suggests How To Install H & R Super Sport Mustang Springs (1996-2004) - Installation Instructions at AmericanMuscle.com and the springs being installed in that guide are the ones i have. Is there a different way to face the pig tails to make the back sit up a little higher? say having the pigtails face the passenger side? or any other type of adjustments i can make? Its undriveable as it sits right now as im afraid i will shred the tires.
Any suggestions would be great
With a side by side comparison to the oem shocks the size looked identical, when at auto zone that was the part number given for my car on their computer, and even when I pulled it up from home that was the part number given. Now I know those databases aren't always correct, so say if it were the wrong size, would that cause the spring to look very tightly compressed? I looked under there this morning and it looks like half the coils are touching each other on the back... Would a lower rated shock cause this?
I was looking online and had found a couple places where you can purchase Gabriel shocks and Struts for 20-40$ Now if im not mistaking that is really really cheapo stuff?!? Get some better quality parts for a lowered car!!!!! Why half ass it???
Patrickg302-if the new shock is physically shorter in length,the rear end would be closer to the body when installed.
Meaning the rear will sit lower then it should.
the rear shocks just control the motion of the car; they have little or no effect on the ride height. You can completely remove them from a Mustang and the springs will still hold up the car, so that's not the issue...UNLESS the shocks are really, REALLY short and are keeping the springs from expanding to the proper ride height
Mransr, Maxpowers-im well aware how a shock and spring works.
"Maxpowers"-read mransr's post,hopefully you'll understand that's its possible.
sorry, it may be "possible" but very, Very, VERY unlikely...on a Mustang the shocks would have to be something like a foot too short for them to compress the springs enough to pull the ride height down from what it would be with the springs on their own...
in other words, for the springs to lower the ride height the fully extended length of the shock would have to be a few inches less than the normal, at-rest length of the correct shock...so while it is theoretically possible, on a car like a Mustang, it ain't gunna happen
Got it all worked out now, my spring isolators were shot, bought some fresh ones and tossed them on there and now it sits up right where it should, they gave me that extra little bit of space to clear the tires from the wheel wells. After comparing the old isolators and the new ones the old ones were quite flattened out, and that seems to be why it sat to low. And my tires are quite large in the back - 285/40/18 so that didn't help either, now that its lowered i think i will be getting some same width, but shorter tires for the back to clear it just a little more, but for now it rides good.
thanks for all the replies
i still dont understand this. isolators shouldnt make that much difference in ride height. i have the h&r ss springs on my car and intentionally pulled both the top and bottom isolators . even still, it dropped only half an inch. granted it was on the front, not the back.
:shrug:
