just noticed a small problem
Shirley
112
Phoenix, AZ
i just took my car out to the convenient store, probably like a 5 mile round trip, and on the way home r. I heard a consistent squeeling noise and a slight I guess you could say burning rubber smell from the front of the car. I am guessing it is the fan belt. Well I went to take it off, and it wont come off. I pulled the idler pulley all the way back and the belt still has no slack in it. When I installed my 3G alternator, I used the pulley that came on it. The belt was a little tight when I installed it, but there was still some slack so i could pull it over the alternator pulley. There is also a slight glaze on the non ribbed side of the belt. Should I just cut the damn thing off?, and does anyone know the exact length of a slightly longer fan belt that I can use with with the stock pulley setup (P/S A/C W/P ALT SMOG IDLER CRANK)? Or should I just buy another stock length? Any help is appreciated.
i got the belt off, and it definitely will not go back on. The pulleys really look to be all aligned, I know that even a small amount off will cause problems, but wouldn't this problem have reared its ugly head earlier?
I also think something else happened. The belt was not tight when you installed the 3G (I have installed two 3Gs on the fox and neither significantly changed the stock belt displacement), but now it is. That suggests something happened.
I have the feeling that in daylight you will be able to spot the issue. Make sure to spin each accessory by hand to be sure they all spin freely. Look for discolored or glazed pulleys.
It's hard for us to offer advice (I am sure you are rolling your eyes at my post, but I miss things that are out of whack all the time, so I know it happens - and to me more than others :bang: ) since this is one of those things where you just gotta size it up yourself.
My two cents. Good luck. :nice:
