Just pulled the following codes
Morales
136
Miami, FL
12 - RPM at idle out of range/high
Car has bumped timing im not sure if thats why the car is throwing that code.. the car idles below 1000 at about 600 rpm
94 - Air Diverter Solenoid Circut Fault :shrug:
44 - Thermactor Air System Fault :shrug:
Can you guys give me any idea of what might be wrong...
thanks in advance
94 and 44 are for the smog stuff. Jrichker has a nice post about diagnosing its issues.
Has your idle setting recently been reset/changed? If the various settings are not in synch, it can confuse the puter.
Good luck.
I don't have my smog stuff on the car anymore.. I deleted the smog pump and capped off all the hoses. could that be why the car is dumping those codes?
and no the idle setting havent been reseted or changed.
Your right on the money..codes are smog related and can be simply ignored.
Yep, I would not sweat the smog codes then.
What is the car doing that is not normal?
Good luck.
Good luck.
Thanks guys.
Nothing really.. I just wanted to pull codes to see if everything was ok. The Airbag light does flash constantly. I thought maybe my code reader would detect that as well, but i dont think it did.
Morales said:
Thanks guys.
Try finding info here .
Good luck.
