  • 1994 - 1995 Specific Tech
just tell me what to do!!!!
  • Thread starter Thread starter justaGTgirl
  • Start date Start date Aug 12, 2008
First Prev 2 of 2
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 12, 2008
#21
  • Aug 12, 2008
  • #21
to :SNSign:
Have you pulled codes yet? How's your fuel pressure at idle, with the vacuum line disconnected from the fuel pressure regulator? You should be seeing ~39PSI. What's your base timing set to, with the spout out? Anywhere from 10-16° base should be good, but you may run into some detonation issues with the higher base timing, if you aren't running higher octane gas. I would suspect the TFI or ignition coil before the stator based on the symptoms you're experiencing. Typically with the stator being bad, it's a no-start, no-run condition, and your fuel pump won't even prime when you first turn the key on.
BlackVert
5,589
9
98
Bethesda, MD
Aug 12, 2008
#22
  • Aug 12, 2008
  • #22
did you change the cam too?
i hear you about not wanting to be reminded of all the money that has gone into it, but we really do need to know as many of the details as possible to be better able to help you figure your problem out. believe me, i have so much damn money into this thing of mine that i am afraid to add it all up.
without a tune, you really need to make sure the mass air meter is calibrated for the injectors you are using. otherwise, the computer will not know how to open the injectors to give it the right amount of fuel
what color are the injectors?
Pokageek
2,767
MA, USA
Aug 12, 2008
#23
  • Aug 12, 2008
  • #23
The stator might be bad in your dizzztributor.
WHITE94COBRA
816
HUNTINGTON BEACH
Aug 13, 2008
#24
  • Aug 13, 2008
  • #24
Do you have your spout reconnected? Have you pulled the plugs to see which cylinder is misfiring? If your still running the stock tune, the car will run like crap, and have some of the symptoms you have now. If it is tuned, the first thing I would look at is spark, you know you have spark at high RPM's, but if you have a bad wire, plug, or coil it will show up at low RPM's. If thats all good, go to fuel pressure, it should be 39* with the vaccuume disconnected. Now if that is good, check into vaccuume leaks, get a can of seafoam, follow the directions on the can, then start looking for smoke comming out of weird places under the hood. Are you getting any detonation (pinging)? Is your exhaust smelling like gas, or is it making your eyes water, does it have any soot around the exhaust exit, is there any smoke comming from it? if so what color? Just a little more info and i'm sure we will get it.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 13, 2008
#25
  • Aug 13, 2008
  • #25
This Tread has been REALLY enjoyable for me to read
RC
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 13, 2008
#26
  • Aug 13, 2008
  • #26
from what I am reading , its just running rich as crap because of the injectors , put the stock injectors and stock MAF back on until you can get the car tuned for the aftermarket MAF and injectors , set the timing at 12 base with spout out , should run decent
Pokageek
2,767
MA, USA
Aug 13, 2008
#27
  • Aug 13, 2008
  • #27
What about the muffler bearings?
'94ChickStang
301
northern ca
Aug 13, 2008
#28
  • Aug 13, 2008
  • #28
RC
Best thread Ive seen in a while
GTA_V6_Mustang
1,326
Miami, FL
Aug 13, 2008
#29
  • Aug 13, 2008
  • #29
I think they adjusted preload on those already. Whats left is the calulu valve
Pokageek
2,767
MA, USA
Aug 13, 2008
#30
  • Aug 13, 2008
  • #30
Hey why did my post get erased. I was just being funny!!
Black95GTS
1,644
Marlborough, MA
Aug 13, 2008
#31
  • Aug 13, 2008
  • #31
The vehicle is low on blinker fluid.
Seriously, what did you do to the car?
Adam
94GTLaserRC
11,178
Aug 13, 2008
#32
  • Aug 13, 2008
  • #32
Adam
That's not it
You need to rotate the tire air!
RC
'94ChickStang
301
northern ca
Aug 13, 2008
#33
  • Aug 13, 2008
  • #33
Stuff a Turbonator in the airbox and you'll be all set! On top of that you'll save 33% more gas...
:stirpot:
94GTCoupe
1,412
92
79
CA
Aug 13, 2008
#34
  • Aug 13, 2008
  • #34
,rotating the tire air is a good observation
seriously,these guy's are just having alittle fun with you.we would all love to help you,but you need to be clear on what exactly the problem is,AND the modifications done to your stang.
for example,if you changed you injectors to a higher flow rate,you need to install an aftermarket MAF calibrated to that flow rate,otherwise the car will run like poop.
i've been on other forum's before and never came across a better group of guy's and girl's than can be found here
just be really descriptive and answer the questions that are asked.
J
justaGTgirl
14
columbia, MO
Aug 13, 2008
#35
  • Aug 13, 2008
  • #35
I've figured it out its the MAF I just got one out of a 98 cobra but the wires are all mixed up so how can I fix it and convert it????? thanks for all your help!!!! she runs good without the MAF pluged in.
J
justaGTgirl
14
columbia, MO
Aug 13, 2008
#36
  • Aug 13, 2008
  • #36
No diagrams
I need diagrams of a 98 cobra MAF sensor and a 94 GT MAF sensor where can I find them?
fastgtfairlane
266
#37
  • Aug 13, 2008
  • #37
i dont think that will work. u just need a maf calibrated for the same size injectors you have and it will solve the problem. if the 98 cobra is not calibrated for the same injectors you have it will not work
Pokageek
2,767
MA, USA
Aug 14, 2008
#38
  • Aug 14, 2008
  • #38
You prolly need a tune too. I put 24#r's on mt 306 and a matched MAF. It DIDn't run...I had to get it tuned or dialed in on a dyno.
BlackVert
5,589
9
98
Bethesda, MD
Aug 14, 2008
#39
  • Aug 14, 2008
  • #39
yeah, i agree ... you should get a maf that is calibrated for your injectors. another option is to swap your original 94/95 sensor into the cobra maf (it fits- i did it a couple years ago), have the new maf flowed, and get a tune. but that would probably end up costing more than just getting a new maf made for our year cars and your injectors. the other thing to keep in mind is that if you have any bends in the tubing between the air filter and the mass air meter, then the sensor's readings can be unreliable.
First Prev 2 of 2
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
