I just bought an 80 model and am putting a light weight stock k-frame under it and i need to know what model did Ford start to put this light weight peice under the mustangs? Also are the spindels on the 80 models the same as the 87 thru 90 models?
Ford never made a lightweight K-memeber, but many aftermarket one's. 1980 spindles are different from 87-93 spindles, but they can work but I belive you would have to swap out the rotors and calipers too.
I'm guessing you mean the K member, as in the structure that the front suspension/engine all bolt to....i've never heard of a "light weight" version, other than an aftermarket tubular version. As for the spindels, they're different after '87. If you're doing the spindel/brake setup, just grab the entire system from a donar car '87+, spindels/rotars/calipers and all...might make things easier for ya.
Yeah I heard that it changed in 1987, but like said above, the aftermarket is probably more worth it if you have the money and cant find one at the junkyard. I dont know about where you guys are, but there are never any 5.0's in junkyards ive been to.
