Need help ok I install a qa1 k-member with a coil over kit also Im changing my 306 and installing a408 stroker I noticed that my front tires are about one inch from the front fender and rubs when turning the wheels is there any way to measure or adjust the k-member also my engine is not lining up with the trans it like a gap also is it common to have alot of room in the rear of the engine once u do the k-member swap it's alot of room from the engine to the fire wall its normally a little please help anyone thanks alot
