K-member ?
  • Thread starter Thread starter 88Stangboy
  • Start date Start date Dec 12, 2005
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 12, 2005
  • Dec 12, 2005
Has anyone used or know of how good Granatelli K-members are?
Or does anyone know of any really good K-members? Im looking
for one and i don't really know about the quality of any of them.
Im looking for the lightest and strongest one...any help would be
greatly appreciated.
C
coming4you
32
Toms river NJ
Dec 12, 2005
  • Dec 12, 2005
ive had a qa1 in my car for over 2 years.. and its great quality the install does however suck compared to some others ive heard of... the lower control arm bolts/nuts have to be ground down nearly to nothing for them to thread on.. Other then that no problems and great room/access to everything needed
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 12, 2005
  • Dec 12, 2005
I was looking at a QA1, will all the stock suspension work with it? Like springs, A-arms...or do you have to run aftermarket A-arms and coilovers?
This is what im worried about, i want to use as much of my existing front suspension as i can for the time being. I will eventually install tubular front A-arms and coilovers, but not anytime before summer.
joncash
just high enough to be functional
756
The USA's peen
Dec 12, 2005
  • Dec 12, 2005
Yep, the QA1 wil work for sure. I saw one get installed on a customer's car w/ the stock front suspension and it fit just fine.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 13, 2005
  • Dec 13, 2005
I have the Granatelli unit. It is a heavier K-member, but very sturdy. More for road racing. I was going to get the GP unit, but they sent me the GMS unit because they said the GP was junk and a liability concern. Got one hell of a deal, a $700 setup for $400.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 13, 2005
  • Dec 13, 2005
Im pretty sure im going to go with the QA1, in Summit it goes for about $230 bucks. I think im going to throw in some tubular A-arms, are the QA1's any good, or is there a better set for about $200-$300.
soontobefastfox
275
Troy, Michigan
Dec 13, 2005
  • Dec 13, 2005
My vote goes for Maximum Motorsport's K-Member.
joncash
756
The USA's peen
Dec 13, 2005
  • Dec 13, 2005
With the QA1 tubular control arms and nearly all others you have to run coilovers because there is no spring pocket for a stock style spring. If yopu can get the money together (or wait for a while) it should be cheaper to get the whole ProActive system in one shot than piece by piece.
J
jerryD
1,061
Gladstone, MO
Dec 13, 2005
  • Dec 13, 2005
THe QA1 will change your wheelbase some. prob move the front wheels forward. some folks don't like it cause then they have tires rubbing the fender well area.
AJE has the whole thing with what you want to do. you can run the k-member with stock arms, just have to buy the spring perch option from them $40. Tube A-arm with spring perch as well, or just a plain tube a arm with no perch? your choice. they have it. www.ajeracing.com
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Dec 13, 2005
#10
  • Dec 13, 2005
  • #10
jerryD said:
AJE www.ajeracing.com
Dito ... or MM www.maximummotorsports.com
blackcloud50
388
#11
  • Dec 14, 2005
  • #11
AJE or www.paracing.com
Maximummotorsports you have to use tubular A- arms and coil over
QA1 moves the your wheels
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 14, 2005
#12
  • Dec 14, 2005
  • #12
yea, see thats what i dont want. I don't want a K-member that moves your wheels but does let you use the stock A-arms and springs. What negative affect does it creat when it moves your wheels? Do you have a gap behind the back or your front tires and the fender? Does it ride different? This is my main concern, i mean the wheel movement...anyone know the negative effects?
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 14, 2005
#13
  • Dec 14, 2005
  • #13
I just looked at the PA unit and it sounds exactly what i want for absoblute sure. I can get everything i need from them including the spring perches. It sounds great for my needs, thanks to all that replied to my thread, it helped me alot!
blackcloud50
388
#14
  • Dec 14, 2005
  • #14
PA unit is the one I was going to use as well when I get one. I also wanted to utilize my stock A-arms and springs. I also heard great things about the fitment and quality as well.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 14, 2005
#15
  • Dec 14, 2005
  • #15
It seems like the best one for the job im trying to accomplish. Im trying
to loose as much weight from my car as humanly possible, but still keeping
it completely streetable and at least some what comfortable. The PA
K-member does that as far as i've heard, the main thing i wanted from it
was it to be strong and not have it bend or the welds crack or anything.
But i also needed to keep my stock A-arms cause i ain't got the money
right now for tubular ones....(Very budget build) But its the one im
getting, hopefully before christmas.
blackcloud50
388
#16
  • Dec 14, 2005
  • #16
Cool...be sure to let us know how it works out for u
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
