  • SN95 4.6L Mustang Tech
KB boost a pump or twin focus pumps?
  • Thread starter Thread starter mat82284
  • Start date Start date Jan 10, 2009
M
mat82284
889
  • Jan 10, 2009
Right now i have a single gt pump, but i have a stock cobra assembly on the way with two cobra pumps in it, but i was wondering, should i buy another focus pump and slap the two in car, or should i use the stock pumps with a KB boost a pump? Do i need a FPDM with the stock pumps? what about the focus pumps do i need a FPDM with them as well?
I'm only looking for 550hp so i know both will work, just trying to see whats the cheaper route, buying another focus pump $100 or buying a kenne bell boost a pump for $250 but if the focus pump requires a FPDM then that changes the cost.
R
Roblu98
94
East Fallowfield, PA
Jan 10, 2009
  • Jan 10, 2009
You will need a new FPDM if you run two focus pumps. You should also up grade you wiring for the fuel pumps and FPDM as well. Lethal Proformance has nice wiring and FPDM up grade kits. Also Kenne Bell has alot of good info on Boost a pump and different pump combinations and there flow rates on there web site. Good Luck!
M
mat82284
889
  • Jan 10, 2009
So my current stock fpdm will work with the cobra pumps? If i swapped them for 2 focus pumps, can i just buy another fpdm to run dual fpdm's, one to each pump?
R
Roblu98
94
Jan 11, 2009
  • Jan 11, 2009
Yes your current FPDM wil work with the cobra pumps everything plug and play. You can run 2 FPDM with the focus pumps but you will have to get the harness for it. They do sell modified FPDM when running two focus pumps.
M
mat82284
889
  • Jan 11, 2009
Whats the max hp for the cobra pumps?
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
