Keep going through header gaskets
Anytime that I have had issues with burning through header gaskets it has always been a symptom of the header bolts loosening up. I put a set of locking header bolts on and have never had a problem after that.
+1
Just make sure you bolts never loosen up and you shouldn't have any problems. I have felpros and have never had a problem. Over a year and still going
felpro 1415's. they actually stick to the headers when they get heated up, kinda like they burn onto them, they always come off in one piece too.
I always run this gasket. even have a header bolt missing on one side and still no leaks. and my headers have individual tubes. The only time i had a leak was when the front drivers primary loosened up enough to where both of the bolts were halfway out, and it blew a tiny part of the gasket out.
iv had real good luck with those layered gaskets, i think its somethin like seal for sures. like 5 layers of metal, crush fit and re-useable, i used to burn thru felpros like crazy, but these have never leaked.. little spendy tho.
Might also try some of this, especially if you've got a mating surface that isn't true.
DisplayImage.asp
