Kenne Bell arrives Monday!
  • Thread starter Thread starter TRICKYGT
  • Start date Start date Jun 22, 2011
1 of 2 Next Last
TRICKYGT
59
Rochester, NY
Jun 22, 2011
  • Jun 22, 2011
When I get home from work Monday there will be 127lbs of joy sitting in my driveway waiting for install. 5 years of pondering and dreaming will soon be at an end!
Clutch was installed last week and I love the feel of it. Certainly wakes you up in traffic. However I have noticed a slight grind/scrape at low revs, can get quite loud in 4th gear at around 1400 rpm under low load. Only driven around 100 miles on it so far and it has quietened a little. Normal? Part of me is thinking maybe they didnt replace some fluid when transmission was pulled and I am going to change it anyway at the same time I install the blower.
Also... anybody know what best spark plugs will be for my new setup?
Shopping list is....
plugs
oil
coolant
tranny fluid
gapping tool
Any other suggestions welcomed.
Rejekt
546
Raleigh, NC
Jun 22, 2011
  • Jun 22, 2011
Luckyyyyyyyyyyyy....
This is what Kenne Bell recommends..
http://www.kennebell.net/techinfo/general-info/SPARKPLUGS.pdf
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jun 22, 2011
  • Jun 22, 2011
The squeeking 'can' be part of the normal wear in. I've done two clutches in the same car where I've been unnerved by squeek that eventually cured itself.
Other possibilities could be that the new clutch has uncovered a weak U-Joint or perhaps the Throw Out Bearing you just installed (although new) is bad off the shelf. Time will tell.
Question(s):
What KB kit did you get? How Much boost? What supporting mods (i.e injectors, MAF, TB, etc.)? Aftercooler kit? Boost-A-Spark? Boost-A-Pump?
Oh... and before pics of your car and engine bay!
I'm totally excited for you. I love my KB. Just wish they had an air to air aftercooler for the Windsor.
D
darkside03gt
851
Sacramento CA
Jun 22, 2011
  • Jun 22, 2011
I would go with NGK TR6 4177 for plugs. They are one heat range colder and a lot of people swear by them.
Dont forget distilled water to mix with the coolant. I would also add a bottle of water wetter to split between the two coolant systems.
TRICKYGT
59
Rochester, NY
Jun 22, 2011
  • Jun 22, 2011
Question(s):
Went with FRPP TO bearing and pilot because I heard Spec supplied bearings not so good. Hoping the noise passes however its at 85000 miles and I have never changed tranny juice so its due some Purple.
KB sells the whole kit, went with the 2.1L intercooled running 9 psi. Reusing the FIPK and 70mm Accufab TB.
I am a photo guy as much as a stang guy so there will be pics. Might even take enough to do a write up step by step if I get frisky. Not really enough info on web sometimes. Might help others take the leap.
TRICKYGT
59
Rochester, NY
Jun 22, 2011
  • Jun 22, 2011
Thats the kind of advice I need and something I would have overlooked for sure.
sneaky98gt
2,387
144
114
NC State University
Jun 22, 2011
  • Jun 22, 2011
Almost everyone with a blower runs the NGK TR6s gapped at .036. They are copper, so they don't hold heat as well as platinum plugs do (which helps reduce the chance of detonation). And I'm pretty sure they are 2 heat ranges colder, but that's tit for tat. They are what everyone runs, and I've never heard of anyone having problems with them.
You do need to change them about once a year, but that's really not a big deal, and they are cheap (~$15 for a whole set).
TRICKYGT
59
Rochester, NY
Jun 22, 2011
  • Jun 22, 2011
I am listening and thinking that they are the route to take. Anything else I might be needing? Not the greatest mechanic but with passion, enthusiasm and attention to detail I'm sure I'll scrape on through the install.
Problem here is that I get it monday, I am working through thursday and friday I will be road tripping to Virginia for vaca, maybe hit North Carolina, Kentucky etc, so it will be at least 2 weeks before I start even thinking of install. GRRRRR
sneaky98gt
2,387
144
114
NC State University
Jun 22, 2011
  • Jun 22, 2011
Beer. LOTS of beer.
1fun281
438
Atlanta Georgia
Jun 22, 2011
#10
  • Jun 22, 2011
  • #10
ive heard bad things about ngk plugs pulling the threads out of the heads? But i dont know, i personally like autolites, i use the platinums because i dont have any huge power adders.. But yea id say go with either autolite or ngk coppers, must be changed about every 10k miles or so
TRICKYGT
59
Rochester, NY
Jun 22, 2011
#11
  • Jun 22, 2011
  • #11
sneaky98gt said:
Beer. LOTS of beer.
There will be a case of Newcastle Brown Ale on standby.
TRICKYGT
59
Rochester, NY
Jun 22, 2011
#12
  • Jun 22, 2011
  • #12
I would pay $10 a plug if I knew I was getting a great product.
NO STRIPPED THREADS!!!! I would cry for sure.
D
darkside03gt
851
Sacramento CA
Jun 23, 2011
#13
  • Jun 23, 2011
  • #13
I have never heard that about NGK specifically. I can tell you however that most stripped threads are a result of 2 things.
1 is some morons still dont understand that aluminum cylinder heads need anti sieze on the threads of the plugs. Without it there is a slight chance of loosing the threads due to the material forming a bond with the spark plug. This is actually one of those things where too much is not actually a bad thing.
2 is cross threading the plugs. to many people dont start the plug by hand and instead go right to the socket wrench.
D
darkside03gt
851
Sacramento CA
Jun 23, 2011
#14
  • Jun 23, 2011
  • #14
Also after you get it all up and running you should really consider flushing your engine coolant system. With a KB or any other twin screw you really want the coolant system to be up to par because they still produce a good amount of heat even with the intercooler.
Make sure you have a second set of hands to help you lift the blower into place when the time comes because its is really heavy.
When you install the egr valve lightly thread the fitting on the tube into the valve and then install the two bolts that hold it to the manifold. After that tighten everything up. It goes on so much easier that way.
Consider making a few brackets and or using nuts and bolts to secure the H/E to the crash bar rather then the self tapping screws KB supplies. I know of two people who have had them come off.
If you are going to run a boost guage there are two extra ports on the manifold on the drivers side to tap into but they have 1/8in npt plugs installed. Remove one BEFORE you install the manifold. Again its easier.
I would consider removing the fittings on the resivior and the sealant they use and replacing it with high temp thread sealer from locktite. I would also recommend doing the same on the heater port fitting on the passenger side. Both of those places leaked on my kit.
Thats about all I can think of for now, hope this helps.
Stumbaugh
903
Russellville, Ar
Jun 23, 2011
#15
  • Jun 23, 2011
  • #15
I'm jealous......
TRICKYGT
59
Rochester, NY
Jun 23, 2011
#16
  • Jun 23, 2011
  • #16
What you doing next week?
TRICKYGT
59
Rochester, NY
Jun 23, 2011
#17
  • Jun 23, 2011
  • #17
Stumbaugh said:
I'm jealous......
All I can say is...... 'if you want it bad enough'.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jun 23, 2011
#18
  • Jun 23, 2011
  • #18
The install is really not all that bad on KB kits. Darkside's post brings something else to mind too...
LOTS of Blue Locktite. I use the stuff that looks like stick glue:
Use it on all hardware that doesn't require sealant.
04GTMustang
348
Stafford
Jun 23, 2011
#19
  • Jun 23, 2011
  • #19
sneaky98gt said:
Beer. LOTS of beer.
^ this and lots of patience. You will hit many speed bumps in the install like I did. None of it was kenne bells fault or bad directions or anything just somethings we would screw up and have to take back apart or needing a tool to make the job easier.
Kenne bell can sound arogant about their tunes being top notch but you know i am now a believer in their statements that other dyno operators dont know their systems.
I got a dyno tune and its terrible lol car ran more like stock with the kb tune than it does now. part throttle isnt good at all right now and i cant go back to the kb tune because im running dual cobra pumps now. I also blow fuel rail pressure sensors quite often now and i ran the kb tune for 2 years before getting a dyno tune and never had a single problem of blowing any sensor. I blow at least 1 a month now.
so that should give you an idea that kb tunes are actually very good.
04GTMustang
348
Stafford
Jun 23, 2011
#20
  • Jun 23, 2011
  • #20
where in virginia are you headed to?
1 of 2 Next Last
Bad Plugs or Bad piston?!? Help
  • 01Stang65
  • Aug 13, 2019
1996 - 2004 SN95 Mustang -General/Talk- Aug 14, 2019
01Stang65
  • Locked
SOLD Kenne Bell Supercharged Ford Mustang Gt Deluxe
  • Sonny1059
  • Dec 15, 2016
  • S197 Mustangs For Sale (2005-14)
4K
S197 Mustangs For Sale (2005-14) Dec 15, 2016
Sonny1059
Spark Plug Gap And Fuel Pressure Problems On 5.0 W/ Vortech
  • 89gtsleeper
  • May 31, 2016
2K
Fox 5.0 Mustang Tech Jun 1, 2016
89gtsleeper
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
99 Gt Turbo Project
  • BoostStang99
  • Feb 18, 2016
3K
1996 - 2004 SN95 Mustang -General/Talk- Mar 13, 2020
alwayshi
A
