Bad Plugs or Bad piston?!? Help
01Stang65
49
I am going to try to be as thorough as possible. I am going to list all symptoms since I have owned the car.
I bought my 2001 GT with 47k miles on the odo. The car now just passed 70k. Since then I have done an O/R midpipe/catbacks, and changed the plugs once (went to autolite which I regret doing). When I installed the exhaust I noticed a hush sound of "air flow" below the passenger seat. I assumed it was a small exhaust leak, never got around to doing anything with it as it seemed harmless.
This is where it gets rough. Ever since I owned the car, I have had an issue with it starting up every once in a while. Sometimes after it would start, it would almost die immediately. Never had an answer for it and it never seemed to cause any real issue. Last year I did a 3-4 gear pull and at the top of 4th gear the car misfired bad. That is when I installed the autolite plugs. Last night, I went to do a 3-4 pull, and when I got on the brakes right after the pull, I completely lost power steering, brakes, lights, and I couldn't hear the engine anymore, so I figured it shut off. I went to turn the key as I was rolling to realize the engine was still running, just at very low rpms. As I tried to put the engine into 4th, the revs were super weak.
There is a ticking coming from right behind the passenger wheel, and I can hear it out the exhaust. I am thinking this is the exhaust leak I was talking about earlier. That can be fixed. However the spark plug on cylinder 6 (3rd one back on passenger side) had zero gap in it when I pulled it out. All the other plugs were fine. I stuck a coat hanger down the cylinder and hand cranked the engine to feel for piston movement and it was moving.
There was a small knocking coming from the other side of the engine bay, but I almost think it is a loose engine mount, the car seemed to be shaking pretty bad.
I'm looking for possible suggestions and past experiences. I will be getting a borescope down in the cylinder sooner than later.
Is it possible you were given the wrong plugs causing the Piston to slam into the plug? Does your exhaust almost sound like a mild cam?
I thought about that but they were the correct plugs... Just autolite. The exhaust didn't exactly sound right after the misfire, but I have a bad leak somewhere, I wonder if I is talked the gasket backwards when I did my midpipe 2 years ago, I don't do hard pulls often and maybe it blew that gasket. I'll install the gasket tomorrow morning and see if that takes care of the ticking.
Either way when I fix the misfire with these new plugs I'm taking it to a shop to have them examine the inside of the cylinders
