  • SN95 4.6L Mustang Tech
KENNE BELL DYNO 14PSI
  • Thread starter Thread starter Saleen s281
  • Start date Start date Sep 5, 2004
  • 3
First Prev 2 of 3 Next Last
GitDat
529
Indy
Sep 6, 2004
#21
  • Sep 6, 2004
  • #21
Saleen s281 said:
i have this problem where when i shift into a gear hard the car would pause but thats only when i have the throttle closed but if i power shift its all good. jim coudlnt figure it out so he said he has to do some research and hopefully fix the problem
USMC_MuSTaNG said:
I have that same issue....hard shifts and the fuel pressure drops for a second when you floor ir again making it hesitate. Let me know how that turns out.[/QUOTE}
Dear GOD!! I thought I was the only one having this problem and thought I was going crazy PLEASE LET ME KNOW WHAT YOU FIND. I have been putting up with this hesitation problem crap for I don't know how long. It seems to stump everybody
neoclasiccl
3,043
Help I can't see !!!!!!
Sep 6, 2004
#22
  • Sep 6, 2004
  • #22
Nice numbers just curious what were the number SAE?
2000BLKGT
361
Toronto
Sep 6, 2004
#23
  • Sep 6, 2004
  • #23
I get something similar to what's being described...but it's not consistent. When it happens, I consider it "driver error"...almost like I'm lazy on the clutch, and too fast on the gas. Sounds like a quick "pop" that I drive right through.
I had to upgrade my stock fuel pump when we tuned my kit (6psi non-cooled) because when you tried to optimize the A/F...she bucked under boost. So we put in an SVT focus pump....oddly flows twice as much as the GT. Totally fixed the problem.
The tuner (Paul Meister at Steeda.ca) is still skeptical on the fuel set up...so we're probably going with with the Cobra tank with dual pumps (I hear there's a sweet aluminum tank available too)..and Paul will probably urge me to go with 42lb injectors. Bigger injectors may sound like overkill on a 6psi set up...but at least it will ensure that the injectors can over-accommodate if neccessary. This will take place next season.
Oddly...I've heard that replacing the fuel filter can be quite helpful...a fairly cheap part...but it does make sense! If the fuel filter is not clean...it could be the weak link too.
My 3 cents (aka 2 cents CDN)
Saleen s281
79
flushing new york usa
Sep 6, 2004
#24
  • Sep 6, 2004
  • #24
do u guys think that the tune is causing the problem because when i had the kenne bells chip i never had this problem.
GitDat
529
Indy
Sep 6, 2004
#25
  • Sep 6, 2004
  • #25
I actually had this problem with my original Saleen blower once I put a smaller pulley on it. I had the BAP back then but no one could ever really tell me what it was Just seems to be worse now with the KB.
U
USMC_MuSTaNG
82
south carolina
Sep 6, 2004
#26
  • Sep 6, 2004
  • #26
I think it has something to do with aftermarket pumps. Guys with the stock pump and a BAP do not seem to have the problem.
GitDat
529
Indy
Sep 6, 2004
#27
  • Sep 6, 2004
  • #27
I have the stock pump and BAP in mine though
Saleen s281
79
Sep 6, 2004
#28
  • Sep 6, 2004
  • #28
i had this problem with my saleen blower too. i did it once in awhile but with the kenne bell it does it alot. i have 50# inj and a 03 cobra tank and pump so i dont think fuel is the problem.
01MustangGT
202
CA
Oct 3, 2004
#29
  • Oct 3, 2004
  • #29
can anyone figure out the hesitation problem yet? because i have KB with 9 psi, whenever i shift from second to third and the gas pedal is on the floor, release the clutch, the car would pause for a second or two, then it engaged and went.
i have no idea wat happen. I have KB chip and injector, and BAP
GitDat
529
Indy
Oct 3, 2004
#30
  • Oct 3, 2004
  • #30
No clue. I've been dealing with this problem for years. Even with my old Saleen super charger. I've had one guy tell me that it might have something to do with the GT computer not being able to adjust so quickly to boost fuel pressure needs or something like that? Hecks if I know. I sure wish someone could figure it out though
crew_dawg16
445
DeKalb, IL
Oct 3, 2004
#31
  • Oct 3, 2004
  • #31
sounds like a problem the guys at KB should find a solution to. I would go nuts if my car didn't go as soon as I hit the gas.
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 4, 2004
#32
  • Oct 4, 2004
  • #32
you guys need a better fuel system.
GitDat
529
Indy
Oct 4, 2004
#33
  • Oct 4, 2004
  • #33
Saleen S281 said he had a good fuel system and he still has the problem
U
USMC_MuSTaNG
82
south carolina
Oct 4, 2004
#34
  • Oct 4, 2004
  • #34
Getting a new chip this week....I'll let you know how it turns out
tl75keith
69
Owings Mills, MD
Oct 4, 2004
#35
  • Oct 4, 2004
  • #35
Raining on my parade
This is the first I'm hearing about hesitation problems from a KB. I was all set to go for a 6lb KB next spring but now . Does this problem only affect you guys running 9+ lbs of boost? Doubtful that I'll ever run more than 6lb for my street car.
Y
YellowJacketGT
108
#36
  • Oct 4, 2004
  • #36
Saleen s281 said:
Great numbers...
Similar setup.. Stage 2 port Comp cams. 14# pulley.
Dyno KB 14#
What pulley do you have on. 14# or 17#.
I had on the 14# for now (11psi showing).
What boost are you actually recording.
Set my air/fuel to 11.5:1).
Y
YellowJacketGT
108
#37
  • Oct 4, 2004
  • #37
Saleen s281 said:
thanks guys. sorry no videos. i have a dss long block with stage 3 ported heads comp cams, jba headers,x pipe and thats about it. jim is not done with my car. i have this problem where when i shift into a gear hard the car would pause but thats only when i have the throttle closed but if i power shift its all good. jim coudlnt figure it out so he said he has to do some research and hopefully fix the problem but over all my car hauls ass
Had a similar problem. When I would shift fast there would be a hesitation a. Sometimes a pop...
Turns out the setting for tip-in (Initial slam) was retarding too much spark. Once we adjusted them problem went away....
S.D.-Stangman
580
San Diego, Ca
Oct 4, 2004
#38
  • Oct 4, 2004
  • #38
nice run!
01MustangGT
202
CA
Oct 5, 2004
#39
  • Oct 5, 2004
  • #39
wat do u mean intial slam? do we have to adjust it by changing something in the chip?
thanks in advance.
Y
YellowJacketGT
108
#40
  • Oct 5, 2004
  • #40
thanks in advance.
Tip-in is a table used to retard spark at initial request for gas. Not sure if this is WOT or at anytime. Timing can get reduced so much it becomes a hesitation or sometimes a misfire.
I believe it also is load specific (setting for load values). Some of the settings reduced the timing as much as 8 degrees. I currently have mine set at 0 for all loads...
  • 3
R
Kenne Bell Supporting Mods for 2002 GT?
  • Rembrant
  • Mar 25, 2025
SN95 4.6L Mustang Tech Mar 25, 2025
R
Expired Kenne Bell 1.5L Supercharger – 1996–1998 Ford Mustang Cobra 4.6L SVT (4V)
  • rockhopperr
  • Jun 25, 2025
SN95 Mustangs For Sale (1994-04) Jul 7, 2025
T
Fuel supercharged 5.0 kenne bell 2.1l
  • tazman1963
  • May 18, 2024
Fox 5.0 Mustang Tech May 19, 2024
tazman1963
T
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
J
For Sale 2003 mustang GT
  • jimted79
  • Mar 22, 2025
SN95 Mustangs For Sale (1994-04) Mar 22, 2025
jimted79
J
