  • 1994 - 1995 Specific Tech
keyless entry install (?)
  • Thread starter Thread starter Rains
  • Start date Start date Dec 31, 2004
Rains
314
Chico, CALIFORNIA!!!
Dec 31, 2004
  • Dec 31, 2004
anyone done this to their stang? (DIY install)
i have pwr locks and saw the KE kit w/ the easy install from Pep Boys for around 30.00... thought it would be cool
MysteryMachine
1,835
Parkesburg, PA
Dec 31, 2004
  • Dec 31, 2004
Eh I tryed to install an alarm with keyless entry myself. Got the alarm for like 75 figured that was cheaper then Ford putting one in for like 300. Started the install thought things were fine was having issues with the lights blinking and was like screw it took everything off and the car ran like **** turns out i zaped the PCM. So much for cheaper DIY lol now i still gotta pay to put it on. Figure at least if a shop does it and messes it up they have to cover it no matter what.
Just plain Keyless is probably a lot easyer though i don't know
Rains
314
Dec 31, 2004
  • Dec 31, 2004
i just bought it... only 6 wires to hook up, its made by Bulldog, looks pretty simple, will install tommorow
hopefully it will work
MysteryMachine
1,835
Parkesburg, PA
Dec 31, 2004
  • Dec 31, 2004
lol wasn't gonna say it and sound cheap but mine was a bulldog. Had a lot more then 6 wires lol. One of these days i'll find someone to hook it up for me
HISSIN50
34
129
Jan 1, 2005
  • Jan 1, 2005
if you understand relays (unless it has onboard relays), you should be alright.
good luck, post if you get stuck.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 1, 2005
  • Jan 1, 2005
I put the Bulldog kit on my DD (Bravada), and it took me about an hour. Make sure you have a multimeter to start probing wires, and it goes fairly painlessly. I'd recommend soldering the wires, since it asks you to tap into some higher amp wires, and you don't want resistance burning up your priceless Mustang. The kit says to splice and tape if I recall correctly.
Matt
Rains
314
Jan 2, 2005
  • Jan 2, 2005
KEYLESS done!! took like 30 mins to get it hooked up and about 30 mins to make it look "pretty"
7 wires, 12V(1), Door lock(2), Door unlock(2), 12v w/ Fuse(1), ground(1)
it came with 2 ok looking remotes, not the usuall rectangle looking one.
i just needed tape, testing light and wire cutters, flat and phillips SD's
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
