knock sensor idea...need input
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
just bear with me on this one since its in the early stages of thought and i dont even know if its possible. i was sitting in my electronics class today and started thinking about knock sensors. and than i was thinking that it would be possible to build a knock sensor module for the 5.0 mustangs. the only thing i dont know is what controls the timing advance and retard on our cars. is it the computer or is it the tfi module on the distributor? if there would be a way to tie in to whatever controls the timing advance with this knock sensor module you could run higher base timing and get more power out of the car and it would be safer for the motor. if you have any input or think its too far fetched let me know. and if i end up making one ill send you one for free, haha. i was also thinking that maybe it could be just wired into a gauge that had a set of leds in it or something that would light up when it detected detonation. it would have to be somewhat adjustable to keep it from going off due to normal valvetrain noises but that could be done with electronics in the module. i dont know, i just need some ideas to get this thing going. thanks
ps. dont steal my idea or i will hunt you down
Timing and fuel are controlled by the computer.
I believe the A9L does have Scalars for a knock sensor, so it may be as simple as using a tweecer to enable the function of the knock sensor.
The A9L was also porgrammed for an e- fan, but not all of them had the proper hardware configurations to run the fan.
There may be products out there that can control spark based upon a knock sensor signal, but I can't think of any.
If nothing else, I am subcribing
jason
yeah, i was searching around today and noticed that the gm guys with early 90s 305 camaros are using something similar what im thinking of but i couldnt find anything other than a few people mention it in some gm forums. the only hard part is going to be designing a circuit that will convert the a/c voltage of a knock sensor to dc voltage and than somehow use that to retard the timing a few degrees. i need to figure out what the signal looks like coming from the computer to the tfi module and see what it does to advance the timing. i mean i had a chip for my first car (v6 camaro) that just T'ed into the throttle position sensor and the signal for the coil packs and at 75% throttle it would increase timing. so why couldnt something like that work to retard timing. hmm, actually i still have that chip in my tool box at home. i might need to dig into it and figure out how it works.
I've often wished there was an economical way to install some
type of knock sensor, even if not terribly sophisticated.
I do know there were a few Windsors that had oem knock
sensors, I believe later model light trucks.
As far as what I've read so far, the "tune" of the knock sensor
must match the particular block it's used in, and in basically
the same position.
MSD puts out an ignition control box that works with knock
sensors (I believe the system comes with the sensor)
but of course it's quite high buck.
yeah, i saw that kit that msd sells. it uses a gm knock sensor. yeah, ive thought about the issue with the frequency that the knock sensor picks up and sends. but i think you could be around that with some sort of electrical filter that would only allow a certain frequency to be rectified and used. but finding out the correct frequency will be the hardest part i think
got an idea from another site. use a relay that allows the signal to flow through it and than when the knock sensor picks up detonation it switchs the relay so that the timing drops back to base timing. it could be hooked into the plug that the spout connector goes in.
This has been done before. On our cars there have been some successes for N/A cars but it gets more problematic with forced induction. If the timing is retarded with no regard to fuel, you can end up with enough of a rich mixture to cause backfiring through the intake (not so desirable). Another idea (I can't claim the credit for it; someone else came up with it) is to wire the knock sensor into a dash mounted L.E.D. So instead of using it to control the timing (it would have to be VERY reliable in order to give it that control), it would just warn the driver that knocking is detected. You can get out of the gas before it becomes an issue (the knock sensor will trip LONG before you'll ever hear it), and could then take steps to find and correct the problem before getting back into it again.
It just leaves finding a good location to install the sensor.
yeah, i saw a thread awhile ago and someone said something about a light. i dont see why killing timing like that would cause a backfire through the intake. the injectors fire at the same time all the time, they just fire faster and stay open longer depending on what the computer is telling it. it would just run rich for a split second which would also kill the detonation. and if its doing it fast enough its not going to run that rich really
It would depend upon how much timing retard was input. Try backing your timing down to 6 or 8 degrees then goose it a couple times. hehe
Disclaimer: Don't really try it. Just illustrating a point. :)
The other thing to consider is reliability. Even if there's no backfiring issue, do you really want your timing to retard because of a faulty signal when you jump out in traffic or go to make that pass.
I'm much more of a believer in a good tune over a knock sensor but at the same time would not mind having an informational "heads up" from a knock sensor light.
In reference to the injectors though... it's not the injectors you have to worry about. It's how far ahead of the piston becoming top dead center that the spark fires. Too early and the mixture is expended before the piston completes it's stroke. Too late and you have unburned gas going out the tail pipes. There's also the issue of that mixture burning while intake valves are open. There are a couple of conditions that can cause that. The one we're concerned with in this instance is ending up with a mixture so rich (because the spark fired so late) that the burn is not completed prior to the intake valves cracking back open.
I've not tried what you're suggesting however... Just things to consider is all.
Dragazz5.0 -
How did you accomodate an sn95 MAF on a fox computer?
What computer are you using?
Chipped?
Daggar is right, it would be best to pull fuel along with pulling spark. Another consequence of pulling spark and not fuel, is the plugs can become fouled.
jason
put it in the water jacket, water conducts vibration really well, I was thinking like those factory ones you see that go into the freeze plug location. come to think of it you could prob make your own with some piezoelectrics and creativity
i mean, i know that with the motor spinning faster it needs to fire the plugs sooner to burn all the gas...but it wouldnt be like taking the 26* of timing and dropping it to 10 degrees for 10 seconds. it would just be a split second until the knock sensor didnt sense detonation. granted if its knocking like crazy the car is going to run like ass because its gonna be retarding the timing so often. but i do get what youre saying about the fuel. maybe ill just try to figure out the idiot light deal.
Part one of two...
Knock Sensor indicator light - Contributed by Larry Fisher
This will take two posts, so don't stop after the first post...
Do-It-Yourself Knock Indicator
Contributed by Larry Fisher ([email protected])
Revised 20 August 1996
In this directory are text and GIF files covering the design of my
knock indicator.
The files are as follows:
circuit.gif a B+W schematic of the knock indicator circuit
I've been using for the past few years.
All parts are identified.
layout.gif a color drawing of the PCB layout of the knock
indicator using a Radio Shack PCB.
parts.txt list of parts for constructing a complete knock indicator,
including mounting box and hardware.
connect.gif wiring connection details for a knock indicator for a Buick GN
drawing.gif a color drawing of the knock indicator I make.
This picture shows what is possible when the PCB
is wrapped in a mechanical design.
theory.txt a text file describing the Theory of operation of the
knock indicator design presented in this directory.
(incomplete at this time.)
knock.zip a ZIP format archive of all of the above files.
Copyright by Larry Fisher, 1989, 1996
Part two of two
parts.txt
nock indicator parts list
17 June 1996
The following parts are used in the construction of the knock indicator.
Prices are current as of June 1996.
Radio Shack parts are listed, since those are most universally available. Many parts are also available from local and mail-order electronics stores at lower prices, especially in quantities of 10 or 100. The author often uses Jameco, a mail-order company having good service and much better prices than Radio Shack.
The author has parts listed below available as a kit for reasonable cost.
Larry Fisher
[email protected]
Parts list:
vendor, part number, description, quantity per package (if > 1), price (US$).
PCB parts list
1 RS 271-018 390 ohm resistor, 1/2W (2) 0.19
2 RS 273-065 piezo buzzer 2.49
3 RS 276-087 Super Bright LED, T1 3/4 red, 2000 mcd, clear lens 1.69
4 RS 276-159 Integrated Circuit PC board, 1.5"x1.5" (2) 1.49
5 RS 276-1620 1N914 or 1N9148 diode (50) 1.98
6 RS 278-772 Ribbon cable, non-shielded (5') 3.99
7 RS 278-1627 Heat shrink tubing (7) 1.99
8 RS 278-1215 22 guage solid hook-up wire (100') 3.99
9 RS 271-1114 390 Ohm resistor, 1/2 Watt, ±5% (5) 0.49
10 RS 271-1337 15K Ohm resistor, 1/4 Watt, ±5% (5) 0.49
11 RS 271-1347 100K Ohm resistor, 1/4 Watt, ±5% (5) 0.49
12 RS 272-1434 1µF tantalum capacitor, ±10% (2) 0.59
13 RS 272-131 Disk capacitor, .01µF (2) 0.06
14 RS 272-135 Disk capacitor, .1µF (2) 0.11
15 RS 276-079 LED snap-in holder (5) 0.59
(Preferred: JE 23077 LMH200 LED mounting hardware 0.13)
16 RS 276-1723 555 timer IC 1.19
17 RS 276-2009 PN2222 NPN transistor 0.59
18 RS 276-1995 8-pin DIP IC socket (2) 0.59
(Preferred: JE 112205 8LPD 0.13)
19 RS 275-1547 Mini SPST momentary switch (4) 2.99
20 RS 275-612 Submini toggle switch 2.89
21 RS 278-1632 4" wire ties (30) 1.59
22 RS 64-2343 double-sided sticky fastener 1.69
Box and external wiring parts list
30 RS 270-230 Molded enclosure, 3.25"x2.125"x1.125" 1.99
(not recommended for use on dashboards;
Preferred: JE 18921 ABS Speedy H2855, 3.125"x2.0"x.875" 1.95)
31 RS 274-274 Miniature (1/8") stereo inline jack (2) 1.79
32 RS 274-284 Miniature (1/8") stereo plug (2) 2.19
33 RS 64-2345 hook and loop fasteners (4) 2.19
34 RS 278-366 Modular cord, 4 cond, 100 ft 10.98
35 RS 278-777 4-conductor cable (30') 8.99
36 OT 3M 558 22-26 guage wire taps (25) 5.00
37 RS 64-3025 Grommets (31) 1.49
38 RS 278-1652 8" wire ties (30) 2.99
Additional parts for optional external alarm
41 RS 273-070 piezo buzzer, 105dB 9.95
42 RS 274-292 subminiature jack (2) 1.79
43 RS 274-289 subminiature plug (2) 1.49
44 RS 278-366 Modular cord, 4 cond (100') 10.98
45 RS 64-2345 hook and loop fasteners, (4) 2.19
46 RS 271-1301 100 Ohm resistor, 1/4 Watt, ±5% (5) 0.49
47 RS 278-1627 Heat shrink tubing (7) 1.99
RS - Radio Shack
JE - Jameco Electronics
1355 Shoreway Road
Belmont, CA 94002-4100
Tel 415-592-8097
FAX 415-592-2503
Orders 800-831-4242
OT - Other; Adequate replacements not available at Radio Shack or JameCo.
Jrichker:
A 95 Ford F150 with a 5.0 engine has the proper knock sensor.
