knocking noise from top of the motor
2002 mustang gt
Was driving home from work and my engine started tapping under throttle. At Idle it runs great and starts up no problem. I am not sure what the problem is with the engine and have not seen anyone else have this problem. Has anyone had this problem or have heard of anyone having this problem.
2002 mustang gt
Hi,
This topend tapping happen at a certain RPM, or heavy under hard throttle or heavy load?
Recently changed fuel grades or fill up at a location you normally don’t?
First time it occurred, was it after you were hard on the car, or did it occur over time?
Can’t mimic the noise by snapping the throttle quick while it’s sitting?
Done any work to the car recently, prior to this?
Does the speed of the noise match with the RPM of the motor?(higher-faster, loser-slower?).
Sounds like it may be spark knock, a sticky lash adjuster, possible broken valve spring.. may also be a belt driven accessory.
Little more info if you have it, please...
-John
