  • SN95 4.6L Mustang Tech
Knocking on cold startup
  • Thread starter Thread starter 2013 Geee T
  • Start date Start date Sep 27, 2005
2013 Geee T
805
Oak Park, CA
Sep 27, 2005
  • Sep 27, 2005
I have this knock when I first start my car in the morning. Almost like there is no oil there at first. Its only a few knocks then it goes away. Anyone else get that or know what it is or if its normal?
xarnyz
  • Nov 17, 2005
I have the exact same 'few' knocks on my '90 5.0 mt when I start it up. Not sure whats goin on but irs so small that I don't worry too much. I barely have time to disengage the clutch or shift into a gear to mess around with the noise Some people recommend switching oil filters. Haven't tried that yet.
I might have more insight to what this problem is if you get some nitrous and :Track:
Make sure to tell me how it goes
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 17, 2005
  • Nov 17, 2005
If you use a crappy oil filter there is no drain back valve so the oil will drain back into the pan.
Use Motorcraft FL-820S ONLY
1LowGT
294
st louis mo.
Nov 17, 2005
  • Nov 17, 2005
bham_gt
94
Birmingham, AL
Nov 17, 2005
  • Nov 17, 2005
+2, need a filter with the drain back valve on it. I use the Motorcraft filter, but mine still knocks just a little at startup if it sits for several days without cranking it. If I crank it every day, it doesn't.
DogVomit
192
Tampa, FL
Nov 17, 2005
  • Nov 17, 2005
It won't hurt.
Remember, it takes a bit for the oil to start pumping. It also takes a while for the oil warm up enough to flow as nicely as it should.
Just don't rev it, during the first cycling of the oil.
sgarlic
3,085
Nov 17, 2005
  • Nov 17, 2005
Definately try the old filter swap. I had knocking with a Mobil 1 filter, and it went away as soon as I swapped back to Motocraft.
silvergt2001
48
Houston, Tx
Nov 17, 2005
  • Nov 17, 2005
That is odd about the filter thing. I was aware of the anti-drainback valve, but I had to switch from the motorcraft to a wix filter to eliminate the knocking.
Outlaw97GT
234
Redneckville, Tx
Nov 17, 2005
  • Nov 17, 2005
Wix are the best filters by far.....
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 18, 2005
#10
  • Nov 18, 2005
  • #10
I am not familair with Wix I will check into that...
menasci
640
Chandler, AZ
Nov 18, 2005
#11
  • Nov 18, 2005
  • #11
I had the same problem.
I used Seafoam and it went away
T
Tommy 00GT
122
Bay Area, CA
Nov 18, 2005
#12
  • Nov 18, 2005
  • #12
at about 75k mi my car developed the same problem as yours. and yes i do use motorcraft filters
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
