KOEO 522
  • Thread starter Thread starter stykthyn
  • Start date Start date Nov 1, 2007
stykthyn
5,232
2,652
223
gainesville
Nov 1, 2007
  • Nov 1, 2007
my friends car wouldnt start the other day so I pulled the codes and came up with a 522.has anyone run into this code before? it says that the car is not in neutral or park while the test is being performed. would this indicate a bad neutral safety switch? it is an automatic vehicle. I ran through the gears and dropped it back in park. still no luck.
stykthyn
5,232
2,652
223
gainesville
Nov 3, 2007
  • Nov 3, 2007
well, I replaced thw neutral safety switch and I am still getting the same code. Does anyone know what causes this??
Hissin where are you??
HISSIN50
34
129
Nov 3, 2007
  • Nov 3, 2007
The MLPS was replaced? Just confirming............
Does the car act-up or is it just a CEL annoyance?
Here's some generic info about the MLPS and some testing specs.
Good luck.
stykthyn
5,232
2,652
223
gainesville
Nov 3, 2007
  • Nov 3, 2007
the car wont start and is taking up space in my driveway. (something my wife reminds me about daily) I thought for sure that it would have been the safety switch, but I guess I was wrong
stykthyn
5,232
2,652
223
gainesville
Nov 3, 2007
  • Nov 3, 2007
where is the mlps located?
HISSIN50
34
129
Nov 4, 2007
  • Nov 4, 2007
The MLPS is the switch on the driver's side of the trans.
They can be real finicky to get aligned properly (one mm can make all the difference).
There's a hash mark on the Neutral position of the sensor IIRC. You put the shifter in neutral and line up the hash marks. Then tighten the two bolts down (they're like 8 or 10 mm bolt heads IIRC).
TCCoA has TONS of info and posts about it if you wanna check that out.
Good luck.
stykthyn
5,232
2,652
223
gainesville
Nov 4, 2007
  • Nov 4, 2007
ok, I am a newb to ford. what is TCCoA?
HISSIN50
34
129
Nov 4, 2007
  • Nov 4, 2007
TCCoA. Just search MLPS and you'll get tons of info.
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
