KOEO Codes
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Jul 17, 2007
slow5.0gt
138
  • Jul 17, 2007
Got the code reader and ran the test on the car, still trying to solve engine idling problems
67---NPS circuit failure
81 air diverter solqeqnoid fault
82 integrated relay control module
85 shift solenoid
84 egr vent fault
Can anyone explain these codes a little more to me and how to solve them?
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
67-was the A/C on during the test?? automatic or manual tranny??
81-do you have AIR(smog pump) on the car??
82-see 81
84-EGR Vac. Regulator-is you EGR System hooked up??
85-i show as CANP. the Evap(charcol canister) purge valve. small cylinder near A/C accumulator passenger side firewall.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 17, 2007
  • Jul 17, 2007
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests. You can generally ignore this code, since it has no effect on engine performance.
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running tests. It also checks to see that the transmission is in Neutral and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the car from being driven while the computer is in test mode. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
The NSS code 67 can be bypassed for testing. You will need to temporarily ground computer pin 30 to the chassis. Computer pin 30 uses a Lt blue/yellow wire. Remove the passenger side kick panel and then remove the plastic cover from the computer wiring connector. Use a safety pin to probe the connector from the rear. Jumper the safety pin to the ground near the computer.
Be sure to remove the jumper BEFORE attempting to drive the car!!!
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
With the with the ignition on, look for 12 volts on the red wire on the solenoid connector. No 12 volts and you have wiring problems.
With the engine running, stick a safety pin in the LT Green/Black wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the cats. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Putting the computer into self test mode will cause the solenoid valve to toggle. If you listen carefully, you may hear it change states.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
With the engine running, stick a safety pin in the Red/White wire for the solenoid valve & ground it. That should turn the solenoid on and cause air to flow out the port that goes to the pipe connected to the heads. If it doesn't, the valve is bad. If it does cause the airflow to switch, the computer or wiring going to the computer is not signaling the solenoid valve to open.
Both 81 &82 codes usually mean that some uneducated person removed the solenoid control valves for the Thermactor Air system in an attempt to make the car faster. It doesn't work that way: no working control valves can cause the cat converters to choke and clog.
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
Code 84 EGR Vacuum Regulator failure – Broken vacuum lines, no +12 volts, regulator coil open circuit. The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
Looks like you are the victum of some uneducated person's attempt to make the car faster by removing the smog equipment.
TAB & TAD solenoid valve eliminators – eliminate codes 81 & 82 and 44 & 94
Don’t do this if you have a catalytic converter H pipe. The catalytic converters must have the air from the smog pump or they will clog up and choke.
See www.Newark.com for the resistors to replace the TAB & TAD solenoids
http://www.newark.com/jsp/Passives/Wirewound/OHMITE/43F82RE/displayProduct.jsp?sku=64K8974
If the link fails do a search using the park number
82 ohm, 3 watt wirewound resistor, 94 cents each.
Newark P/N 64K8974
Ohmite part # 43F82RE.
Pay a visit to your local Radio Shack to get some heat shrink and some crimp on tap terminals. They do not stock the resistors. Or you can use the Ford connector pin kit from AutoZone.
18 gauge crimp on taps Catalog #: 64-3053
Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAD solenoids if emissions testing comes to your area.
Two flat pin connectors.
One 82 ohm, 3 watt resistor.
One piece 3/8" heat sink tubing 2" long.
Two pieces 3/16" heat shrink tubing 1 1/2" long.
Solder the pins onto the resistor leads using electrical solder.
Slide the 3/8" heat shrink tubing over the resistor.
Slide the two pieces of 3/16" heat shrink tubing over the two wires, leaving the flat part of the pins uncovered.
It helps to have the resistor leads straight and not bent as shown in the first picture when you apply heat to the heat shrink tubing. That way, the tubing shrinks more evenly.
Finally, apply heat to shrink all the tubing uniformly.
Bend the leads to fit the spacing on the female TAB & TAD connector sockets.
Push the connector pins of the completed resistor assembly into the empty female TAD or TAD connector sockets on the wiring harness. The resistor assemblies replace the missing solenoids: one resistor assembly per solenoid socket.
Do not crimp on the pins and wrap the mess with electrical tape and say you got the idea from me. If you do, and I hear of it, I will say unkind things about your intelligence and family heritage. Do Quality Work!
This information is for informational purposes only and is intended for use only on off road vehicles. It should not be used on any vehicle operated on public roads.
Operating a vehicle modified in such a manner on public roads is a violation of the EPA codes regarding modification of emission controlled vehicles.
93 LX
3,081
Norwalk, CA.
Jul 17, 2007
  • Jul 17, 2007
I still get those TAD and TAB codes and I got new solinoids. Oh well it they do not effect idle quality so dont waste too much time messing around with them. In fact with the exception of the 1st code those codes are more for smog diagnosing. Do a cylinder balance test and check for vacuum leaks. My 86 had a bad PCV hose which runs under the upper intake. YOu cant buy one from the parts stores however LRS has one. I made one from steel hose and a some 3/8" fuel line.
slow5.0gt
138
  • Jul 17, 2007
82-see 81
81-82 I am not aware if I have a AIR system in the car then again I know little about it at all.
84-- no the egr system is disabled removed completely.
85-- if it is the little canister off to the side on the firewall anything going to that area is either cut or missing completely, just a mass of wires hanging over there.
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
85- correct (about an inch in diameter)
as jrichker said: "Looks like you are the victum of some uneducated person's attempt to make the car faster by removing the smog equipment."
gerzen
71
Chihuahua México
Jul 17, 2007
  • Jul 17, 2007
now i know why i have the 85 code, i cut the conectors of the CANP solenoid, i use the conector of that one to make an extention of the conector of my ACT to relocate it to the air filter box, i notice like you said a smell of gasoline under my hood, so i want to reinstall the solenoid, how i know which of the two conectors in the solenoid is the (+) and which one the ground? and in the electricar arnes near to the water temp sensor? well in that i can open the key and see whit a probe lamp which one is the (+), im rigth? so how can i reinstalled?
cjones
1,561
Avondale, AZ
Jul 17, 2007
  • Jul 17, 2007
what year is you car?? so i can give you the correct wire colors.
gerzen
71
Chihuahua México
Jul 17, 2007
  • Jul 17, 2007
is a 1991 GT 5.0 AOD
cjones
1,561
Avondale, AZ
Jul 17, 2007
#10
  • Jul 17, 2007
  • #10
CANP - GY/Y - to comp. Ground switched/controlled.
R - 12v with key ON
did that answer it or did i miss something??
gerzen
71
Chihuahua México
Jul 17, 2007
#11
  • Jul 17, 2007
  • #11
that´s great, just one more thing, at the solenoid side any of the two conectors can be installed at the ground or the positive cable? it´s the same or it have one conector for the ground and one specific for the (+)?
cjones
1,561
Avondale, AZ
Jul 17, 2007
#12
  • Jul 17, 2007
  • #12
i don't believe they are specific. it just powers a solenoid(an electromagnet) and i have never seen one that cares which direction the current comes from
slow5.0gt
138
#13
  • Jul 18, 2007
  • #13
Yea I figured that the codes i pulled are mainly emissions control, Im figuring that I need to do a KOER test to find out what is wrong with my idling.
93 LX
3,081
Norwalk, CA.
Jul 19, 2007
#14
  • Jul 19, 2007
  • #14
well then post us the codes
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
