ladder bars
  • Thread starter Thread starter JMD Engineering
  • Start date Start date Dec 28, 2005
J
JMD Engineering
102
Northern VA
Dec 28, 2005
  • Dec 28, 2005
So i was talking to a couple guys at my shop the other day- and i expressed the fact of my traction problems. One of the guys there says he put Ladder bars on his 5.0 and his rearend hooked like no other. he breifly describe how they work and i was immediately intruiged. But then i thought to myself- if this works so good, how come not many people run this setup? Which is why im here to ask these couple questions-
- is this a common task (installing LB's)
- does anyone make them or do i have to fabricate them myself
- is the install worth the traction result
90NotchBack
306
Loxahatchee/Pembroke Pines, FL
Dec 28, 2005
  • Dec 28, 2005
A lot of people run this set up. On most Drag car are laddar bars cars. Everyone now a days are going 4 link set up. There is a lot you would have to do to install laddar bars. You need to get brackets welded around your axle tube. Then your going to have to get a crossmember welded in the car. So you have something to mount the laddar bar to. You are going to have to run coil over shocks.
Maryland Stang
1,656
30
39
Greenville, NC
Dec 28, 2005
  • Dec 28, 2005
I looked into this just last week and came to the conclusion that it just wasn't worth the effort on a street car like mine. If you're going to go to that much trouble you might as well ditch the 8.8 and go with a 9". Then you end up with a rear end that hooks so good that you're breaking driveshafts, trannies and mounts, bell housings, motor mounts and bending the body up. Once you spend quite a few thousand dollars to get all of that straightened out you find that you don't have enough engine to take advantage of the rest of the drive train and end up spending 30 grand on a worthy engine.
bobcatv8
141
Ocala,FL
Dec 28, 2005
  • Dec 28, 2005
Your car already has a 4-link rear suspension from the factory.
Unless you plan on making crazy horsepower and hitting the rear end REAL hard, you would be much better off working with the factory set-up. Get a set of high quality adjustable upper and lower rear arms with drag-race friendly bushings, reinforce the mounting points {floorboard} and go from there.
Ladder bars will require a complete revamping of your rear suspension. Not really needed for a street-strip Mustang. The 8.8 can be made to live in drag racing fairly well.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 28, 2005
  • Dec 28, 2005
To some effect, the stock suspension on the mustang is a ladder bar setup, a set of lower and upper controll arms. That is one reason mustangs are such good drag race platforms. I would do a ladderbar setup when I make enough power to snap the 8.8, and need to tub/backhalf the car. People get amazing traction with UCA and LCA setups located in the stock mounting locations.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Dec 29, 2005
  • Dec 29, 2005
Next winter I plan on dropping the upper arm body mount ~1 1/2" for a better instant center and welding up my torque boxes. I put 3:73 gears in the car and I plan on running some drag radials or slicks at the strip.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
N
Dyno Issue with 2015 GT
  • Nickos.Ford
  • Jul 11, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 11, 2025
Nickos.Ford
N
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
Brakes ABS in a Fox - Mark Bettin
  • AeroCoupe
  • Mar 28, 2025
2K
Fox 5.0 Mustang Tech May 17, 2025
AeroCoupe
