Last min check...
SVTLink
49
Garland, Tx
Okea I'm finally putting my engine back together this weekend. Since my Timing chain sensor wheel broke, is there anything else i need to look for? I tore it down to pretty much the block, removed the oil pan to take out the pieces and bought lots of new parts. Is there anything I should be worried about? Since the sensor ring broke, would that affect my timing? The ring only goes on a certian way I think...Any advice or info would be great
:flag:
97 Mustang Cobra
If your timing chains didn't jump a tooth on their cogs your timing should be the same...you should just have to slide a new sensor wheel back on there and put everything back together...
I'd get a haynes or chiltons manual so you know all the proper torque amounts and settings for the bolts...Remember to put some black RTV at all the head to cover seams and at the pan to cover seams (should be 10 spots that need the RTV)
