Well the whole install not hard. My problem is with wiring. I have been staring at diagrams for a week now. I know I need to repin everything.
The dash and cluster are from a 93 and I'm installing it in a 80. I don't really know where to start explaining. Lets start with the cluster. After repinning everything where it needs to go according to the diagrams it wont work right. Tach, Oil pressure, and left turn indicator work fine. Everything else Cluster lights, fuel gauge, Battery gauge etc... don't at all.
I know it might be a little time consuming to tell me exactly where each pin goes. So just as much help as your willing to give is all I'm asking.
I have the Headlight switch working good but not the dimmer. In the 1980 switch the dimmer and the switch is one in the same. The 1993 are separate I don't have a diagram for the 93 dimmer. So have no Idea how that hooks up!
Also the multifunction switch in the 1980 its 2 switches for blinkers and wipers it's all in one for the 93. I'm slowly getting that one though.
Any help what so ever would be awesome and I would be forever in debt.
Thanks
I know it might be a little time consuming to tell me exactly where each pin goes. So just as much help as your willing to give is all I'm asking. I have the Headlight switch working good but not the dimmer. In the 1980 switch the dimmer and the switch is one in the same. The 1993 are separate I don't have a diagram for the 93 dimmer. So have no Idea how that hooks up!
Thanks
