Late model rims on a classic
  • Thread starter Thread starter tweet66
  • Start date Start date Jul 17, 2005
T
tweet66
589
Pennsauken, NJ
Jul 17, 2005
  • Jul 17, 2005
Question for anybody who has put late model wheels on classics (specifically Bullitt rims) What size spacer/adapter did you use? What are your front and rear brake setups? I just bought a set of 17" x 8" Bullitts for my 66 coupe for $175 and I'm trying to figure out what size spacer to use. I have granada discs up front and 10x2.5" drums in the rear. Any suggestions and where to get them?? TIA.
Ken
12sec67
1,301
San Diego, Ca
Jul 17, 2005
  • Jul 17, 2005
Ken
there are plenty of threads on this subject... try a search
67coupe351w
424
Portland, OR
Jul 17, 2005
  • Jul 17, 2005
I have the 17 by 8 bullits on my 67.
The rears bolted right on, all I needed to do was cut the flange that stuck out into the wheel well off that was part of the axle bump stop.
The fronts required an 1.25 inch spacer to clear the upper A-arms. However I didnt like the way this looked, although the wheels were still inside the wheel wells (barely) it looked like the front wheels stuck out too much. Also with the shelby drop and 1 inch lowering springs I was very worried about tire - fender contact.
I found a shop in town that will narrow allumium wheels. So I had the 2 front wheels narrowed down by 1.25 inches so I could eliminate the spacers. This allowed the 225/45R17's tires I have on the front to fit the wheel MUCH better (the outermost ring of the wheel doesnt stick out) as well as the wheels are tucked inside the fender where they should be.
67efivert
348
lincolnton nc
Jul 17, 2005
  • Jul 17, 2005
on my vert i only got .700" spacer with 17X8 cobra rims its lowered and so far no real problems but i had to use 3 bolt upper control arms ( oh and my .700" spacer was a custom made piece)
allcarfan
The Answer Man
2,458
North Atlanta
Jul 18, 2005
  • Jul 18, 2005
what backspacing are on your wheels? 5.72" ?
On a stock 66 coupe, you will need 1" spacers on the front and the rear. If you swap in a 9" rear from a 67-68 mustang, you will not need any spacers in the rear because the rear is 2" wider than that of the 66.
I have a 66 with bullit wheels. No spacers on back with a 69 mustang rearend...245/45/17 tires...no rubbing. On front I have a 1" spacer...no rubbing...225/50/17
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 18, 2005
  • Jul 18, 2005
I just put 18x9" bullits on my 70.
Used a 1" spacer which results in 5" of total backspace (rims are 6" stock).
Could have gotten away with 1/2" spacer (5.5" backspacing).
T
tweet66
589
Pennsauken, NJ
Jul 18, 2005
  • Jul 18, 2005
12sec67 I tried search but there wasn't anything mentioned specific to the Granada front discs.
Thanks for the replies.
allcarfan, can you post a pic? Are you still looking for a set of the PBR caliper adapters? I trying to have a couple sets made up in the next couple of weeks if my damn house would just stay together long enough to let me play with my toys when does home ownership get to the "joy of" part????
blkfrd, what size tires are you running?
C
ctlaw74
24
  • Jul 18, 2005
Late model Bullitts on a 66...
17x8 Bullitts
FRONT 4.75" backspacing, (225/45/17) granada discs, shelby drop and drop springs. No rolled fender and no rubbing...
REAR 4.5" backspacing, (235/45/17) stock 8" rear drums, Mustang Plus 4 and 1/2 leaf springs. No roll, no rub
Hope that Helps!
THE RATTLER
T
tweet66
589
Pennsauken, NJ
Jul 20, 2005
  • Jul 20, 2005
spacers
ctlaw74, that's exactly what I was looking for THANKS.
Sweet car by the way, is that an original color?
66StangFastback
181
norman, oklahoma
Jul 20, 2005
#10
  • Jul 20, 2005
  • #10
Ya...what color is that? It looks really good, and the chrome wheels look really good with it.
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
Price?
  • Blueinfan
  • May 27, 2022
  • What is it Worth?!?!?
5K
What is it Worth?!?!? May 30, 2022
7991LXnSHO
F
88 Upgrade to 5 Lug/Disc Brake Conversion Confirmation of Plan
  • Firehawk335
  • Aug 10, 2020
10K
Fox 5.0 Mustang Tech Jan 28, 2021
derek1993
Planned Cross Country Run - 65 Fastback
  • Smokinstang65
  • Aug 17, 2021
4K
1965 - 1973 Classic Mustangs -General/Talk- Feb 27, 2022
Baron von K 289
