Later model inertia switch fit earlier models?
Mikey1968
232
Kommiefornia
Will the red-button later model (early to mid 90s) inertia switch fit into my 89 GT that currently has the white-button model?
I'm thinking my inertia switch is causing an intermittent fuel pump shut off......you guys think the switch can do that? I've changed everything else....fuel pump, ignition switch, pump relay......
I've read that the red button version is the newer style and will interchange with the white button.
You could bypass the inertia switch for testing purposes by connecting a jumper across the harness plug that goes to the inertia switch and see if the symptoms change.
