  • SN95 4.6L Mustang Tech
launch
  • Thread starter Thread starter 98gtblue
  • Start date Start date Jan 20, 2004
98gtblue
237
houston
Jan 20, 2004
  • Jan 20, 2004
best way to launch on stock gears and clutch.
Teen'93stang5.0
3,560
813
Jan 20, 2004
  • Jan 20, 2004
um, on street tires, lower tire preasure about 10psi below what it sais on the tire, rev to about 2500 or 3000 and drop the clutch, if you spin feather the gas and powershift once its time to shift
KaPPaBaLL
1,326
BAYAREA
Jan 20, 2004
  • Jan 20, 2004
what tires do you have?? good burn out on stock tires avoid water box... rev to 3k-3.5k feather the clutch.. dumping is no good. It will eventually fawk up your drivetrain. Feathering itself wears the clutch faster but better than your axles breaking off..
Teen'93stang5.0
3,560
813
Jan 20, 2004
  • Jan 20, 2004
how does feathering the gas wear out the clutch?
and if you are going to burnout, only do it till you see smoke, you dont need to do a pro-stock burnout on street tires, itll hurt traction, and i doubt youll break axles on a lightly nmodded stang with an 8.8 and prolly 2.73 gears
KaPPaBaLL
1,326
BAYAREA
Jan 21, 2004
  • Jan 21, 2004
feathering the clutch not the damn gas pedal. I was assuming he had a 99+ but now that i look. I'll try to be clearer next time.. Not used to people talking about feathering the a gas pedal...
Security Check at each access?
  • Mcmahst
  • May 10, 2026
  • Feedback Area | Testing Zone
Feedback Area | Testing Zone May 11, 2026
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
R
Kenne Bell Supporting Mods for 2002 GT?
  • Rembrant
  • Mar 25, 2025
SN95 4.6L Mustang Tech Mar 25, 2025
N
Drivetrain Think I blew my trans first time running at the strip
  • Nismoboyo
  • Jul 15, 2024
SN95 4.6L Mustang Tech Jul 16, 2024
85GTStangGuy
