LCA's
  • Thread starter Thread starter 04sonicblueGT
  • Start date Start date Nov 19, 2007
First Prev 2 of 2
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 20, 2007
#21
  • Nov 20, 2007
  • #21
04sonicblueGT said:
i guess i just can't understand that only 1 company makes a decent control arm.
Well there's 2 factors in control arms:
1. Build Quality/Durability
2. Intended Use
Griggs makes the best race parts bar none, but they are not really intended for street use.
MM does have the best of both worlds, they are not better than Griggs but they will last longer, and perform right underneath Griggs'
Under most of the others, 'Intended Use' is out of the question, they create more trouble in your setup than 'relieve'
I'll be back on later to finish
blackfang
1,290
Richmond, Va
Nov 20, 2007
#22
  • Nov 20, 2007
  • #22
I forgot about Griggs. probably because they deal more with roadracing and I am a dragracer.
C
ccramer
14
New Jersey
Nov 20, 2007
#23
  • Nov 20, 2007
  • #23
I have used both MM and J&M/Pro3 control arms and the quality and finish is the same. I think the J&M arms have a better bushing design with there patent pending 3 piece poly-ball setup. I am currently running the J&M street/race weight jack version which has the spherical bearing on the axle and 3 piece poly on the chassis side and I have not had any increase in NVH if that is a concern.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 20, 2007
#24
  • Nov 20, 2007
  • #24
The wall is a bit thicker on the J&M's
First Prev 2 of 2
J
K-member Question Racecraft
  • jAEded
  • May 4, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2014
90lxcoupe
Help Looking For Cs6/8 Hood?
  • trigga415
  • Sep 29, 2014
  • 2005 - 2009 Specific Tech
2K
2005 - 2009 Specific Tech Oct 2, 2014
trigga415
Drivetrain Suspension Keeps Breaking
  • chriscash
  • Jun 30, 2013
Fox 5.0 Mustang Tech Jun 30, 2013
88LX5.Oh
Suspension SVE Rear Lower Control Arms (RLCA)
  • nine2oneGT
  • Dec 22, 2012
  • SN95 4.6L Mustang Tech
14K
SN95 4.6L Mustang Tech May 2, 2019
Boricua86
After Market Upper Control Arm Rubber Bushing Will This Work?
  • 5.0TailPipeHump
  • Aug 28, 2013
6K
Fox 5.0 Mustang Tech Sep 14, 2013
5point0stang88
