  • 1994 - 1995 Specific Tech
Leak Down Question...Part Deux!
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Aug 22, 2005
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 22, 2005
  • Aug 22, 2005
Well, I decided to fork over the $$ to get the leak test down the right way....dont want to take any chances.
Thanks for those that replied on my previous post about the leak down, but have more specific question.
I want to be able to communicate knowlegeably with the tech. Are there specific numbers that I should look for in the test, or is it specific for each engine.
I have pretty much stock lower end (everthing b/t the headers and lower intake is stock.
Just to want to get BS'd about the results.
If the test is good, Im gonna pick up the Snow Kit and get it put on in a week or so.
Thanks
RC
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Aug 22, 2005
  • Aug 22, 2005
You were having a local shop do this right? I was curious, why did they wanna do a leakdown test prior to installing the meth. kit? I'm guessing it'll give a good indiciation of the integrity of your engine's guts, just curious as to what they were wanting to see? I'm looking at getting one soon, just doing my homework here. I remember you mentioning blowby, maybe they're trying to see if a rebuild would better suit you? If you got any info, please share, thanks
Hef
AznStanger3v
2,026
Northern VA
Aug 22, 2005
  • Aug 22, 2005
the magic number is LESS THAN 5%
Cobra_Dusten
246
Marysville, Wa
Aug 22, 2005
  • Aug 22, 2005
5-7% is acceptable, but less than 5% is where you wanna be, For what its worth, my car just did 15-18%... time for a new motor...
94GTLaserRC
11,178
Aug 23, 2005
  • Aug 23, 2005
5% WHAT???
Is there not a PSI pressure that is read on the gauge?
Hef: Under high boost, the dipstick pops out a little. I will be adding more timing with the Meth kit, hence more power. I dont want to add more power if there is an integrety issue.
You dont have to do a leakdown simply to add a Meth kit...Im just worried about another issue.
RC
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Aug 23, 2005
  • Aug 23, 2005
RC, I figures that was the logic, thanks
forget that leakdown, beat on it till the dipstick and a bunch of other stuff pops out!!! j/k, good luck
94GTLaserRC
11,178
Aug 23, 2005
  • Aug 23, 2005
I May have done this, except I dont feel like having a fire in my engine at 80mph on the hwy because oil splashed out of the DS tube.
RC
Cobra_Dusten
246
Marysville, Wa
Aug 23, 2005
  • Aug 23, 2005
5%, a leak down test pushes air into the combustion chamber and measures the amount that leaks out, it displays the percentange on a gauge, you are thinking of a compression test.
94GTLaserRC
11,178
Aug 23, 2005
  • Aug 23, 2005
Gotcha... The Comp test is the PSI measurement correct?
So I looking for less than 7% if I want to slap on the Meth kit without any further motor work?
RC
CManT1914
3,172
Killeen, Texas
Aug 23, 2005
#10
  • Aug 23, 2005
  • #10
RC
Yes and yes.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
