]Kilgore Trout said:That is the crankcase ventilation tube. It allows gases that build up in the crankcase to go into the combustion chamber.
It is not so much leaking as it is that your engine is ridiculously dirty. Why is your engine so dirty? Don't you care about your Mustang?
Clean your engine.
Clean your engine
MikeZ28 said:in the cam cover there is a baffle setup that supposed too block excess oil from getting into the vent tube. i would check that. plus you may want too replace that rubber peice that connects the plastic tube too the cam cover.
Kilgore Trout said:I agree with MikeZ28 because he knows his stuff...
DEEPSEAGT said:Whats the deal with my Master brake Cylinder. Alawys has crap on it is this commen for an 02? Maybe I should upgrade to a Cobra Master when I do My Brake upgrade.
