  • SN95 4.6L Mustang Tech
Leaking Gas And Water!!
  • Thread starter Thread starter ChargedUp
  • Start date Start date Nov 22, 2017
C
ChargedUp
  • Nov 22, 2017
two parts...
1. Car smells of gas bad and I noticed puddle in spare tire storage once. I heard it’s the grommet but doesn’t appear to be leaking there. Any chance it’s elsewhere? If not how bad is grommet change?
2. My convertible top separated from rear window a little, wondered what glue to use to reattach it.
Any input is appreciated
squeak93
2,317
392
164
Joplin, Missouri
Nov 22, 2017
  • Nov 22, 2017
The filler neck grommet isn't too bad and can be a major cause of gas fumes. You have to drop the tank to do at least the filler neck grommet. The leak inside of your spare tire is something to investigate as well. There is a truck floor seal that could be bad as well on the filler tube.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 22, 2017
  • Nov 22, 2017
Good luck on that. My experience with convertible tops says that it's leaking because the fabric has worn out from repeated bending right at the corner of the glass. Because the fiber has lost it's strength the glass has become detached.
When I encountered this issue and researched I attempted multiple times a DIY repair. Fail. Ended up having the rear windscreen part of the top replaced.
Regarding the filler neck. IF your Mustang has a plastic rock shield around the filler neck it may have rusted out under the plastic. FWIIW the Mustang's gas tank is one of the easier ones for the DIY'er to drop. It does make the job easier for the tank to be as nearly empty as possible.
C
ChargedUp
  • Nov 22, 2017
WHere is the trunk floor seal? Is it just a grommet? And that leads directly into the gas tank?
My window is only separating a few incxhes from adhesive coming off should be fixable
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 22, 2017
  • Nov 22, 2017
Just wondering. Is it gas or water in the trunk?
I guess I assumed it was water in the trunk but the car smelled of gas.
It might also help if you mentioned the model year of your car.
rancorkeeper
484
Palos Heights, IL (Chicago suburb)
Nov 22, 2017
  • Nov 22, 2017
wmburns said:
If your Mustang has a plastic rock shield around the filler neck it may have rusted out under the plastic.
This could very likely be the culprit - it was a common problem on 90-96 GM B-bodies & they would get a strong gas smell inside the cabin.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Interior and Upholstery Water leak, passenger side, ripped seats and carpet out already.
  • 2000ElectricGreen
  • Mar 18, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
squeak93
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
