Leaking Injector?
  • Thread starter Thread starter D0cks
  • Start date Start date Mar 24, 2004
D
D0cks
94
  • Mar 24, 2004
My 91 mustang is gettin real bad gas milage, and i also noticed that if im going say at 3k rpm and i let off, it seems to kinda jump a little bit as the rpms are falling. Anyone have any ideas? what do u guys think i should try? Injector cleaner? im also gettin bad fuel pressure heh
D
D0cks
94
  • Mar 24, 2004
anyone? please?
D
D0cks
94
  • Mar 24, 2004
Nooooo i cant let this fall to the bottom!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2004
  • Mar 24, 2004
ISP's Internet connection burped... again...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2004
  • Mar 24, 2004
OOPs ISP burped...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2004
  • Mar 24, 2004
Here's a way to test for leaking injectors: Connect a rubber hose to the injector where the fuel rail would normally connect and apply compressed air to the rubber hose. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. If the injector leaks, it makes bubbles.
Second method is the cylinder balance test. Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
arbailey
199
New Jersey
Mar 26, 2004
  • Mar 26, 2004
Good tip.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
