leaking injector
i did a cylinder balance test and it was #1 injector so i used a noid light in the socket for that injector and it was staying on even with key off....i think ii got another bad computer now cause its bucking at all rpms missing ill be driveing and the rpms just fall off then back up and down this is making me mad:bs:
Have you checked the 10-pin connectors behind the intake yet? These are the injector wiring harness connections. After 15-20 years or so, they start to lose their connection strenght and start doing all funky things with the fuel injectors.
If you have the jumper harness for these, remove it, then clean off all the gunky dielectic goo, spread the pins open with a small pin and reconnect
Ford Fuel Injection 10-pin Connector Fix
no i havent done the 10 pin yet. im getting code 11 pass, and code 9 cbt pass,and code 94 and 44 emissions delete.i had 1 defective computer took it back got another one now its bucking like a random misfire dont know if its distributer or another bad computer
