  • SN95 4.6L Mustang Tech
Leaking rear end questions!.
  • Thread starter Thread starter hotdog71
  • Start date Start date Jan 16, 2008
hotdog71
427
Seattle, Eastside
Jan 16, 2008
  • Jan 16, 2008
Hi All,
I have what I believe to be a leaking pinon seal and it's leaking quite a bit now it's coming from the front of the diff were the DL goes in is that the pinon seal?
If yes I am guessing the whole rear end has to come out to be replaced?
Any comments welcome.
thanks
R.J.
813
Warwick, Rhode Island
Jan 16, 2008
  • Jan 16, 2008
That is your pinion seal and the whole rear end does not have to come apart to replace it. BUT the cover should come off and the backlash be checked after the new seal is in and the pinion nut is re torqued. If you back lash in now out then the correct shimming would have to be installed to correct the backlash. At this point the whole rear end will have to come apart.
hotdog71
427
Seattle, Eastside
Jan 16, 2008
  • Jan 16, 2008
Thanks for the comments
The backlash is fine in fact I am really only worried about pulling it out in case it doesn't go back in as good that would really suck
I am think about getting Ford to do it in case it gets messed up.
thanks
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
