Leaking water
  • Thread starter Thread starter twindragons187
  • Start date Start date Oct 20, 2005
T
twindragons187
39
pa, ny
Oct 20, 2005
  • Oct 20, 2005
i just installed a new water pump on my 88gt, and there's still water coming out. i also changed the thermastat. the water is coming from the timing cover and the block, but there's no water in oil. is it hard to change the cover gasket? and is there any short cuts to doin this? any info would greatly be appreciated... thank you
Duston
FORCED2DV8
458
Grand Rapids MI
Oct 20, 2005
  • Oct 20, 2005
No its not hard, just time consuming, and not really any shortcuts if you want it to last along time without leaking again.
T
twindragons187
39
pa, ny
Oct 20, 2005
  • Oct 20, 2005
ok thanx.
gregpro50
140
Binghamton NY
Oct 20, 2005
  • Oct 20, 2005
Are you sure its actually leaking between the timing cover and the block?? I have never had that happen. Could you have had the water pump gasket slip when you installed the new pump or the T-stat gasket slip?? I have had that happen.
J
jerry beach
2,671
Ocala,FL
Oct 20, 2005
  • Oct 20, 2005
Is water running out of a spot that you can clearly see?
If not is it puddling on top of the timing cover, and leaking very slowly?
If that is the case I have two 302's leaking there right now. The trick is to drain out some of the water, dry it up, and plug the two holes in the back of the timing cover with JB weld. Its hard to see these holes, but you can feel them. They will be at the front edge of the puddle that I described. Apparently many of them leak here when they get old. Cardudeusa brought this to my attention. I still havent fixed it because it doesnt leak enough to count, it never runs onto the ground, just seeps.
T
twindragons187
39
pa, ny
Oct 20, 2005
  • Oct 20, 2005
yea, its coming from the cover to block, where the bolt goes through the waterpump and cover to block. when the cars off, i can squeeze the top hose and u can see it come out between the block and cover, looks like it more or less, blew the gasket upwords. its a real pain, and leaks all over the ground. it did the same with the old pump and therm. so i thought it was 1 of the 2. fixed them both, and come to find out, it wasn't it. the leak is on the passenger side. it puddle's up and then runs down the block. it leaks enough to where its a hassel. bout a gallon a day. and with it getting cold out, just can't do it no more. i plan on taken the motor out and putting it into my 92 lx untill i get my 306 back.
OL' WHITEY
273
Weddington, NC
Oct 21, 2005
  • Oct 21, 2005
The last time I got a pump from the Ford Dealer, they gave me the wrong gasket. I had a hard time convincing them that it was wrong because their computer said that the part was correct for my car. All the bolt holes lined up perfectly, but the gasket was still not right. After much arguing with the dealer, they finally took the pump/gasket back. I ended up going to a performance shop here in Charlotte and getting the Ford Racing water pump. As it turns out, it's the exact same pump but it did have the correct gasket. AAAANNNDD it was $30 cheaper than the dealer's OE part. After I got the new pump with the correct gasket, I put it on the copier and faxed a copy to the Ford dealer and told them to match the gasket with the one I had taken back to them earlier. They saw the difference and finally apologized for the error. They said that evidentally ALL their pumps have the incorrect gaskets for our cars.
I'd bet good money that you have been given the wrong gasket as well. That sucks! Just go get a Fel Pro gasket and bolt it back up.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 21, 2005
  • Oct 21, 2005
Last December, I replaced my timing cover gasket because it was leaking between the block and the cover [right next to the water passage.] It took the better part of an afternoon to disassemble the front of the engine. The smog pump bolts were the worst.. make sure you clean the gasket surfaces really good and use a small amount of RTV around the passages just to be safe.
T
twindragons187
39
pa, ny
Oct 22, 2005
  • Oct 22, 2005
the pump itself isn't leaking. its the passage way between the cover to block. right next to the bolt. i'm not too worried bout the smog pump b/c i just put the elminator kit on it 2 days ago(smog locked up). but thanx for the info. greatly appreciated.
9
92notchback347
29
#10
  • Oct 22, 2005
  • #10
take the two bolts out by the passages and load them up with pipe dope sealer mine leaked a bit and it cured my problem.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
