garystocker Member Jan 2, 2005 305 0 17 New Jersey Jul 1, 2007 #1 Jul 1, 2007 #1 leaks from pinion shaft as well...what does it need, new axle bearings seals and what else? pinion bearing too?
D D.Hearne New Member Sep 29, 2000 11,730 6 0 south louisiana Jul 1, 2007 #2 Jul 1, 2007 #2 You need to pull the pinion yoke to determine that. Might just need a new seal. So too on the axles. Pull em and see what you've got first.
CanyonCarver515 Member Jun 27, 2007 122 0 17 El Lay Jul 1, 2007 #3 Jul 1, 2007 #3 Sounds like seals all the way. Doest the rearend hum or vibrate? Mine is humming and I need a new bearing. It also leaks on one side...
