Lean In Both Banks
phwsman
Kentucky
Hi
I'll try to run you through this as specially as I can
I bought an 06 V6 in October and the CE light came on and it was discovered to be running lean
On closer inspection it was found that the precious owner had cut out the guts of the converters and welded it shut taking the air sensor with it
So I replaced the entire exhaust and converters and replaced the air sensors
I also added a short pipe cold air intake
Now if I back it out and shift into drive downhill I get lean in both banks and occasionally a cyl 2 misfire
If I go uphill nothing
I have also thoroughly cleaned the MAF, TB, AIM. Reset the computer and did the normal drive in procedures
The cold air intake said it did not require a tune.
Any thoughts?
Thanks
Unless the pipe on the CAI is the same diameter as stock where the MAF sensor is situated, the MAF transfer curve will be off and the engine will run lean.
It's therefore possible that the ECU does need to be retuned.
Reactions: 1 user
