I have an 87 GT with stock MAF (Cali Model),intake manifold and throttle body. It's had a problem with the check engine light blinking on and off before. I figured it was just a short somewhere, but then I noticed that when I drive the car for a while the check engine light will come on and stay on instead of blinking on and off. I checked it out and it the code that I got on the Engine running test is a lean fuel mixture. What would cause a lean mixture? How might I correct it?
I have installed:
K&N Filtercharger kit
Mac 1 3/4" Shorty Headers
2.5" Magnaflow High Flow Cats (O2 sens. have less than 12,000 mi on them)
2.5" Flowmaster Cat-back system (2.5" from headers to Tailpipes)
Ford Racing Clutch, Flywheel, Quadrant, and adjustable cable w/ BBK Firewall Adjuster.
I replaced the fuel pump in May of '04 just because it sounded a little weird to me.
I also replaced my alternator with a PA Performance 130 amp.
My initial engine timing is set to 10 BTDC.
I have installed:
