I was making around 330-340RWHP and I ran 30# inj at 43psi and was actually a little lean up top, I had a high pressure 255lpg pump feeding. Since I could see my injectors were at 84% duty cycle on my Speedbrain they were not enough and I was going to go to a 36# or 42# and tune around it. Ever notice how most of those NMRA P/S cars run large injectors? 310ci, 10 second monsters....
The mph is very low for that kind of power, and with that much torque he should get down the tracker a good bit quicker...gotta love those FTI cams.
Pro-M has always had issues with a 24# cal on 75mm Bullet, the curve just ins't perfect usually they are rich down low and lean up top. The 76mm C&L ran very good for me, but I did find my power was smoother when I switched to an 80mm Pro-M and combined with a 4" AFM power pipe I picked up a couple tenths both on and off the bottle. I say a switch to the 30# inj is a good start... buy the $25 sample tube for the C&L before you spend $300+ on the Pro-M.
What do you launch at? I use to leave at 5800rpm on my 26" x 11.5" ET STREETS, NA I would trap about 5200rpm 115-116mph.
The dyno is a tool...it is not gospel. In my expierence and some of the others I know we find you need more fuel at the track then on the dyno
Read the plugs....white is lean, you want a nice charcoal brownish color.
