Ok, I'm redoing my entire front end and money is no option. This includes the suspension and the brakes, but aside from the spindles we'll worry about the brakes later.
I currently have a Flaming Rivers rack, manual, for pre 94 mustangs. A QA1 tubular K-member, steel C/C plates with spherical bushings, and a strut tower brace.
For the brakes, I would like to use the 94-95 spindles, and due to the year of my vehicle I must buy aftermarket lower control arms and run a coilover conversion.
Before you tell me what I should get I must inform you that I will not replace my rack or struts because they are brand new and I will not use ball joint spacers because that is cheap.
I know that SN95 control arms, struts, and tie rods are longer which makes for a wider track and so I'm not into that.
I'd like to keep my stock track, and reuse what I already have.
I'm assuming you can use the Steeda X2 balljoints to mate 87-93 control arms to 95 spindles so lets start there. This means I can buy 87-93 tubular control arms and swap out the balljoints to X2 allowing me to use the SN95 spindles and not change my track or travel.
Due to the lowering of the vehicle and the desire to change so much I will be using aluminum offset rack bushings to raise up the rack, and use a bumpsteer kit in place of my flaming rivers outer tie rods.
I guess I'm looking for a confirmation here on this setup. I'd like to know if it sounds good to you suspension guys, and if it should keep the current wheel track and travel or will things not work.
To summarize:
QA1 Tubular K-member, C/C plates, strut tower brace, sensatrac 87-93 struts, coilover conversion kit 87-93, X2 balljoints, 95 spindles, bumpsteer kit 87-93, offset rack bushings, 87-93 manual rack and pinion, 87-93 tubular lower control arms with X2 balljoints.
To summarize:
