  • 1994 - 1995 Specific Tech
Lets talk about brakes
  • Thread starter Thread starter stprorolla49
  • Start date Start date May 21, 2007
1 of 2 Next Last
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
May 21, 2007
  • May 21, 2007
This summer i would like to replace my stock front GT brakes with 13" rotors and Cobra calipers. Buyfordracing.com has the kit for $359 with Cobra calipers, Brembo rotors, pads, and rubber lines. While this is a good deal, i kinda want to get slotted and dimpled/drilled rotors instead, and I think it would probably be wise of me to get stainless lines also. That being said, where is the best and cheapest place to get a set of decent zinc-coated slotted and dimpled/drilled rotors that, paired with the $200 i would spend on the 10th anni Cobra calipers from buyfordracing.com, would put me around the same price. I would like to spend under $400 shipped for everything.
Also, is there anything wrong with these rotors?
http://cgi.ebay.com/ebaymotors/MUST...3QQihZ006QQcategoryZ33564QQrdZ1QQcmdZViewItem
They are $120 shipped which means $320 with the Cobra calipers from buyfordracing.com...that leaves me with around $80 for lines, new fluid, etc. Can this be done cheaper? Any suggestions in the brake department would be greatly appreciated. Thanks
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 21, 2007
  • May 21, 2007
The only concern I have with buying crossdrilled rotors is whether or not they were done correctly. That's not to say the ones in that ebay link aren't a quality part, but if they're crap and fail... you have no brakes. Definitely call ahead to see if they have the calipers in stock. From what I've been seeing, everyone has the Cobra calipers on backorder. I've been looking for a couple days, and the places that don't advertise having a backorder make me nervous. I'm looking to replace my brakes with black Cobra calipers probably next week. I'm thinking of doing them at all 4 corners though, and I'm pretty sure the GT and Cobra share a common caliper in the rear, but have a different mount and larger pads, so that would make life a little easier, or at least make it easier on my wallet.
I
inphiniti
412
Providence, RI
May 21, 2007
  • May 21, 2007
i know this doesnt really answer ur question... but i ordered the black set thru BFR.com... couldnt be happier... i DO plan on goin w/ the slotted rotors down the line, but for now, theyll do... but definitely a good choice which ever way you go... dont forget shipping as well on some things where ever u buy, weight will be a bitch... if u order from BFR.com, they sent mine DHL and the ass clowns left it right in front of my front door... couldnt even open teh screen door to get it...
Therian
The Highlander
Waterloo, Ontario
May 22, 2007
  • May 22, 2007
You'll find when you crunch the numbers, that you simply will not be able to undercut buyfordracing's package price.
Check out stangsuspension.com for stainless lines. I've had very good luck with them, and their customer service is top notch. I went with the MM lines because I'm a sucker for a good product.
I too, pieced together my kit, but I made sure that I didn't cheap out on the rotors, as cheap sets are known to be prone to failure and premature cracking. Try to get a guarantee on the rotors, that way you'll know you're safe.
stprorolla49
1,455
15
39
May 22, 2007
  • May 22, 2007
Hmm...the rotors i posted have a 90 day warrantee and full replacement on manufacturers defects...is that the kind of guarantee you mean? Or do other companies have lifetime warrantees. If i did decide to get stainless lines (which dont come on the bfr.com kit), thats another $50 making it over $400. If im going slightly over $400, there was a guy in the 4.6 section that got the bullitt calipers (loaded), dimpled and slotted rotors from rotorpros.com, and stainless lines from stangsuspension, and paid a total of $420 shipped.
Therian
The Highlander
Waterloo, Ontario
May 22, 2007
  • May 22, 2007
The rotors I got from summit (when they were still offering them) come with a two year replacement guarantee. I've never felt like taking a risk on ebay rotors (especially if they're drilled) but some people have been lucky.
go-stang5.0
2,244
Glenview,Il
May 22, 2007
  • May 22, 2007
If you are thinking drilled and or slotted rotors wil improve performance they wont. Unless of course you are using the cheapest of cheap brake pads...
If you want it for looks then go right ahead, but watch out for the bad drilling of certain rotors.
stprorolla49
1,455
15
39
May 22, 2007
  • May 22, 2007
yea im not sure i want drilled ones...my friend scott (raceoholic330) told me that dimpled and slotted is a lot better, and way less prone to cracks
94-302-vert
1,947
NE CT
May 22, 2007
  • May 22, 2007
Honestly.. the stock brake rotors from buyfordracing.com are great....
stprorolla49
1,455
15
39
May 23, 2007
#10
  • May 23, 2007
  • #10
Yea, i guess ill see when the time comes. I definately like the look of the slotted/dimpled rotors better, and if im gonna redo the brakes, i definately want something that looks nice as well as having good function. Are the Brembo rotors included in that set zinc-coated? That would be a huge decision for me because i hate when the rotors start to rust and look like ass.
94-302-vert
1,947
NE CT
May 23, 2007
#11
  • May 23, 2007
  • #11
not zinc coated, but why not paint the hubs or zinc them yourself?
stprorolla49
1,455
15
39
May 23, 2007
#12
  • May 23, 2007
  • #12
How do you zinc coat them?
Pokageek
2,767
MA, USA
May 23, 2007
#13
  • May 23, 2007
  • #13
Yep. Unknown by many even auto-crossers, cross-drilled is a gimmick by all means. If you want fancy looks and less surface area stopping power - buy them.
94-302-vert
1,947
NE CT
May 23, 2007
#14
  • May 23, 2007
  • #14
I saw a zinc coating spray at Lowes a while back... it was in the electrical aisle... My bud sprayed his hand... it was just like spraypaint...
Pokageek
2,767
MA, USA
May 23, 2007
#15
  • May 23, 2007
  • #15
Since we are talking about brakes. I have 17" bullets in the front...my new 13" cobra brakes will work with those..right?
I
inphiniti
412
Providence, RI
May 23, 2007
#16
  • May 23, 2007
  • #16
you should be fine with no problems... my stock tri-bars JUST clear it... so if these are gonna clear it, you should have no problem
Pokageek
2,767
MA, USA
May 23, 2007
#17
  • May 23, 2007
  • #17
Cool. Thanks for the reply inphiniti.
94-302-vert
1,947
NE CT
May 23, 2007
#18
  • May 23, 2007
  • #18
My 99 gt wheels also fit fine...
stprorolla49
1,455
15
39
May 23, 2007
#19
  • May 23, 2007
  • #19
the thing about that though is that its a surface spray which will wear off as soon as the pistons on the caliper press on the rotor, its not a coating...ive seen the spray you are talking about...the zinc-coated rotors are dipped in a zinc plating, so they stay nice...
Therian
The Highlander
Waterloo, Ontario
May 23, 2007
#20
  • May 23, 2007
  • #20
as long as you drive your car regularly, the area on the rotor that is touched by the pads should never be rusty. The inner circle, towards the hub can be painted, and since the pads never touch that area, it will stay clean for at least a year.
1 of 2 Next Last
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
