Let's talk Oil and etc....
KFRG
41
Hey Guys, bought a 5.0 with just over 60K on her. Owner states the car has been running conventional oil. I know many here run synthetic oil's such as M1 etc.
I also know the potential of leaks the synth oil can cause.
Basically, what I am asking is the switch to synthetic worth it, and what are the benefits of doing so if I already change my conventional oil often (no more than 3K, the car will be a weekend driver). I honestly do not want to have to deal with oil leaks at all.
If I stay conventional, what is the best grade (weight) and brand out there for our cars (I live in the Northeast)? I am sure the preferred grade/weight has changed over the years than what it states on the oil fill cap. I also take it a NAPA or Motorcraft filter is best?
Coolant: Any preferred brand you guys use?
Rear-diff: I have heard of guys using everything from synthetic oil to ATF, what is the best stuff to fill the rear up with?
Anything else I should change besides the spark plugs and wires?
Thanks alot guys. :flag:
people have argued about this forever in previous posts. i'll just state what i use and that i'm happiest with it over other things i have had before. if you don't have oil leaks now, i wouldn't worry about oil leaks with switching to synthetics...
5-30 synthetic motor oil, whatever major brand is on sale (worth it)
royal purple synthetic in the diff (worth it)
regular atf in the tranny, it didn't seem to like the synthetic stuff (not worth it)
thats just me though. may not really help much at all, or any, but an extra couple bucks for something that could make it perform better, or last longer is def. worth it in my opinion. i'd also get an air filter you can clean also (k&n?). coolant is coolant if you ask me. all just ethylene glycol, unless they came up with some new additive or something.... haven't bought it for a while.
I would stick with the conventional oil. When I bought my 91 GT almost 7 years ago, it had about 55,000 on it. I started off using Penzoil and a Fram filter, then switched to Castrol GTX 10w-30 and a Motorcraft filter. My dad owns the car now, but I still do the maintenance for him and use the same parts. I contemplated switching to synthetic as well, but never did and don' t plan to. I don't think this is an apples to apples comparison, but I used Mobil 1 on the stock motor on my 89 LX. It burned oil, but also had 100,000 miles on it and a GT-40 intake (known for sucking oil through the PCV and into the runners).
I just use the regular Prestone coolant.
I would leave the rear diff fluid alone.
If you still have the original plugs and wires, you probably want to change them. If the wires are original and have the year on them, save them. The Ford Racing wires are fine for replacements, as well as Autolite plugs. I forgot the gap out so somebody will have to help out here, but I think it's .048 or .053.
I always use Valvoline Synthetic blend 5w30 and ONLY Motorcraft oil filter. IDK about the Foxes but for mod engines it has a check valve that keeps the oil form completly draining into the pan :nice:
I'm a big fan of Valvoline Maxlife. I've been using it for 4 years in my Mustang and i beat the hell out of it on a regular basis and it's got over 250k on it so i would say it's doing something good.
I have been using castrol gtx 10w30 my car's whole life and it seemed pretty damn good, but with the new build I am running some crap 5w30 for break in oil then switching to castrol syntec blend in 5w30.
You can get 5qt jugs of mobil 1 10w30 @ walmart for just over 20 bucks. Though its not a true class 4 synthetic, its still better than regular oil. Not saying regular oil is bad, unless the manufacturer specifically says the engine needs synthetic.
Thanks for the replies guys. I think I will just stick with conventional for now. Grn92LX, you live in NY as well, do you run 10W30? Just trying to gauge the best grade to use as it seems poeple run a variety on the forum, I guess depending on climate location.
Also, a real stupid question, these cars take 87 right? Assuming since these are not high comp. engines.
Thanks again guys, I pick the car up tommorow.
I just picked up a 5 quart jug of Mobil 1 10W30 @ walmart for $22. 10W30 or 10W40 is fine. I'd go 10W40 now for the warmer months if you can. Mobil 1 doesn't make it in 10W40.
You can run 87 no problem and you should be ok running it with slightly bumped timing. None of my cars run on 87 :(
Thanks man. I wonder if Motorcraft or Castrol makes a 10W40, i'll have to check that out. Mabye during the winter a 5W30 would be a good choice.
Yeah, the car is basically stock minus gears, headers, and exhaust so 87 should be fine.
I would run synthetic on a freshly rebuilt engine with new rings, but on a 100k+ engine i'd stick with conventional, maybe a blend. Then again, i run strictly Mobile 1 synthetic in the Merkur but being a turbo engine i want extra protection since the oil also supplies the turbo and it has to stand up to extreme heat.
If you were going to run different weights for summer and winter i'd do: 10w30 winter and 10w40 summer. Either one all year round is fine though.
I run the mobil 1 in my Audi 1.8T engine like 85_SS mentioned above about turbo cars and heat.
Castrol GTX and Motorcraft FL-1A here.
I'm not a big synthetic oil fan. In fact, it's sometimes not recommended in manual transmissions because it makes it too slick and the synchros can't grab the gears and slow them down. I know Tremec now states to run conventional ATF in it's 3650 because of that exact reason.
Any approved oil will be fine. I also have been switching over to HDEO's as the conventional stuff loses all its ingredients.
Run the least viscous oil that maintains decent pressure at all times.
As others stated, I like synthetics for extreme climates or extended OCI's. Something like a zero-weight-synthetic could be nice on a fresher mill in the winter, but otherwise you're probably ok.
FWIW, the Motorcraft oil is very good stuff (the lighter weights are blends) and it's priced pretty decently.
Good luck.
I just started using the Blended Synthetic in my Mustang as it sits for extended intervals. My Lifters have never liked 5W-30, so I just stick with 10W-30 and a FL1-A Filter!
