Lighting MAF ???
  • Thread starter Thread starter southernstang97
  • Start date Start date Dec 3, 2005
southernstang97
176
texas
Dec 3, 2005
  • Dec 3, 2005
this is on a 93 gt 5.0
is anyone running a light MAF on there 5.0 ? if you have one can you tell me how it is wired up , which wire goes to which ? I had to get a new clip from a newer stang so I would be able to use the lighting maf. The stock 5.0 clip has 4 wires and the lighting has 6. and the colors do not match.... someone please help , pics would be great !! southernstang@sbcglobal.net
thanks :SNSign:
just4bob50
504
Pa.
Dec 4, 2005
  • Dec 4, 2005
I got mine from (emustangparts) on ebay and they also had the pig tail to splice into the factory harness. The original MAF for the 5.0 has 4 wires labeled A,B,C,D. On my lightning MAF the wires that are labled A,B,C,D, are the four center wires of the 6. They also run in the same order. When splicing the wires together make sure you solder the connections and seal them up with heat shrink. I had a friend who just did the but splice and after about a year he started having prob's because of corrosion in the splice not sending the proper voltages to the ECU. After he did it the right way the problems went away. One more thing, if you use the new MAF you will need a way for your ECU to reconize the new MAF. Also these meters arent calibrated for injector size like a C&L or Pro-M. Good luck
southernstang97
176
texas
Dec 4, 2005
  • Dec 4, 2005
would you remember what color order that was ?? thanks for the info
F
FobraR
120
Southern California
Feb 1, 2006
  • Feb 1, 2006
If you are looking at the MAF harness with the wires going away from you, stock 4 wire goes A, B, C, D from left to right. Looking at the LMAF harness (6 wire) in the same orientation it will go X, A, B, C, D, X. Don't use the slots I labeled 'X'. So essentially wires go in the same orientation, but don't use the 2 outside spots. Oh and the LMAF is for 42lb/hr+ injectors. Hope this helps.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 1, 2006
  • Feb 1, 2006
southernstang - you realize you have to load the transfer function of the Lightning unit into your ecu using a twEECer or chip, right? You can't just wire it into your existing harness and have it work properly...
D
Daggar
3,902
  • Feb 1, 2006
LMAF is not calibrated for 42s. It's not calibrated for use with our EEC-IV at all. Using one requires a custome tune. It's the computer that is setup to use that meter in combination with 42s on the Lightning.
Edit: Mike beat me to it.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 1, 2006
  • Feb 1, 2006
As Daggar alludes to - once the transfer function is loaded into the ecu so the ecu and maf are literally 'on the same page', you then pull up the screen which allows you to select the injector size you're gonna run. You TELL the ecu what injectors you're running via the twEECer or chip -- and it will make the appropriate calculations on pulse width.
just4bob50
504
Pa.
Feb 1, 2006
  • Feb 1, 2006
ya, what I said
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • dan50
  • Jul 18, 2026
dan50
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Taillight upgrade?
  • BeardIsRed
  • Feb 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
