Lighting/Wiring Question
  • Thread starter Thread starter Steve69
  • Start date Start date Feb 25, 2006
Steve69
233
  • Feb 25, 2006
Hi Guys
I have a 69 Mustang and the interior lighting isn't the greatest because there
is no dome light. It has the rear quater lights and the under dash lights.
I bought a Rearview mirror off Ebay that is a Newer Cobra mirror with combination map light & dome light. It has 3 Wires, ground, Full time Power
which is for the map lights and door trigger wire. I tested the lights and they
work, but the door trigger light wire works when it is connected to ground.
I figured it would work when connected to positive when the door is open the
power would activate it and come on. **Question: How am Im going to
connect or splice this into my interior lights to make it come on when the the
doors are open? Thanks for the input
Steve
Az Pete
711
18
49
Panama City, Fl.
Feb 25, 2006
  • Feb 25, 2006
You could use the door switch power to activate a relay that would then ground the map light set up. Standard relay from any auto parts should work.
Steve69
233
  • Feb 25, 2006
**********Anybody Else**********
Thanks
BarnStang
1,260
Hagerstown, MD
Feb 25, 2006
  • Feb 25, 2006
Thats the fastest and easiest solution. I assume the 69 door switch toggles 12 volts and not ground. If your mirror needs a ground, you will need to switch it with a relay. The door switch will activate the relay coil.The relay contacts will have the mirror light wire on one side and ground on the other. It can go right under the dash.
67efivert
348
lincolnton nc
Feb 26, 2006
  • Feb 26, 2006
just flip flop the constant power and ground so it becomes a switched power i got a 99 mustang mirror in my car works just fine mayby i wired mine that way not even reaizing it
Steve69
233
  • Feb 27, 2006
Thanks for the help
It looks like I have a couple of options.
Steve
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
