Lights
  • Thread starter Thread starter Cobain03
  • Start date Start date Feb 25, 2004
Cobain03
996
Lexington, Ky
Feb 25, 2004
  • Feb 25, 2004
ok, with the headlights off: no drivrs turn signal and passenger is ok but slow. with parking lights on: passenger is ok and slow and no drivers turn signal. with headlights on: no parking likghts and no front turning signals at all.
any suggestions???
6Stang7
1,470
Livermore, CA
Feb 26, 2004
  • Feb 26, 2004
Hmmmm, I am gonna take a shot in the dark here (no pun intended) but I would stay that either your headlight switch and/or volt reg is bad.
-Shaun
69grande
61
Colorado Springs, CO
Feb 26, 2004
  • Feb 26, 2004
maybe a ground problem. try checking for that.
TIGGER
877
244
104
Portland, OR
Feb 26, 2004
  • Feb 26, 2004
First of all, I think the parking lights are supposed to go out when the headlights are on. That is how my friends 64.5 is as well as my 67 coupe. However, they are supposed to blink when the turn signals are on. I think 68 is the first year the parking lights stay on when the headlights are on.
I would check the turn signal switch. Check the connection at the bottom of the column. I would also pull the wheel to see what condition it is in. Maybe clean out the contacts. WHen I first started restoring my 67 coupe, the right rear tail light would never blink or brake. I tracked my problem to the turnsignal switch. I repaired the switch but it didn't last too long. I ended up replacing the switch and have not had a problem since. Good luck
crushnut
870
Oregon
Feb 26, 2004
  • Feb 26, 2004
I have a 68 coupe and my parking lights do not stay on when my headlights are on, they only blink when i use the turn signals
3spd on floor
1,099
Acworth, GA
Feb 26, 2004
  • Feb 26, 2004
yes, the parking lights are supposed to go out when the headlights go on.
I also agree with 69grande and say check out the ground points. My lights did some really funny things when i had a bad ground on the passenger side by the radiator. Also i've seen trailer lights go nuts with a bad ground. Just locate the ground points and remove the screw that holds them in, use some light sandpaper to clean up the surface metal and then put the screw back in with maybe some conducting grease.
If that doesnt clear it up, get out the multimeter and some handy four-letter words.
Cobain03
996
Lexington, Ky
Feb 26, 2004
  • Feb 26, 2004
ok we got everything working only thing the front parking lights goes out when you turn the headlights on i am being told thats the way it is ....... now is there way i can change that so they stay on??
TIGGER
877
244
104
Portland, OR
Feb 26, 2004
  • Feb 26, 2004
So what was the problem?
3spd on floor
1,099
Acworth, GA
Feb 26, 2004
  • Feb 26, 2004
Cobain03- I'm sure there is a way to change it so that they stay on, and its probably not really that hard, but i dont have a wiring diagram here to do it with. Just get a shop manual with the wiring diagram and custom wire it, if you really want them all on at once.
Cobain03
996
Lexington, Ky
Feb 27, 2004
#10
  • Feb 27, 2004
  • #10
tigger.... what we found was the front turn light blub was not in all the way it wasn't turn so that the turn signal was getting contact,,, funny huhh,, the bac was the same way i guess some one doesn't know how to install bulbs the main thing was that i thgought the front park lights was supost to be on we change the headlight switch anyway the inst, lights work better the old one had a lot of cors.. on the little coil in it so thanks guys for all the help we hope we can be some help sometimes!!!
bud4660
459
Mesquite, Tx
Feb 27, 2004
#11
  • Feb 27, 2004
  • #11
If you want the front park lights to stay on. Find the wire going to the rear tail lights at the headlight switch. and tie the wire from the front lights to it. That way they will all light together.
Bud
3spd on floor
1,099
Acworth, GA
Feb 27, 2004
#12
  • Feb 27, 2004
  • #12
if you're going to go to the trouble of rewiring the parking lights to come on with the headlights, you might as well spend the extra 15 bucks and put in a relay system for the headlights, i did it to mine and it really makes a big difference in the amount of light you get from the headlights. very cheap, easy and effective mod.
L
Lswhat
126
Orlando
Feb 27, 2004
#13
  • Feb 27, 2004
  • #13
ok well how do u put one in id really like to run halogens but they burn up light switches so i took them out
3spd on floor
1,099
Acworth, GA
Feb 27, 2004
#14
  • Feb 27, 2004
  • #14
http://www.geocities.com/midlife66/wiring/Halrelays.html
i followed this page exactly, and it worked perfectly. You can do the whole thing in about a half hour. i mounted the relays in a tupperware container on the drivers side by the washer fluid resovoir, but soon enough it will be replaced with an aluminum box.
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
