Assuming you have checked the wiring, Check your turnsignal switch and the light switch. I had the same problem and it was my light switch. As far as getting your headlights brighter, well, there is this little switch on the floorboard you have to push with your foot. Seriously though, I drive around with my brights on all the time. It helps a little if you just adjust your headlight beam up some.
Tyler
