  • SN95 V6 Mustang Tech
lightweight drive shaft?
  • Thread starter Thread starter mustangmat99
  • Start date Start date Mar 1, 2004
mustangmat99
167
  • Mar 1, 2004
i was wondering, will a lightweight drive shaft do any good on my v6? a freind of mine, who thinks hes a big car wizz, says the lightweight ones only work if u exceed 120 before it matters if its lightweight or not, is that true or no? after a few mods i plan on doing before the shaft, i should be up to about 200 or so at the rear, so will a light weight drive shaft let the horses get to the rear easier and increase them? or will it just be a waste of money?
5-SpeedStallion
230
Tampa, FL
Mar 1, 2004
  • Mar 1, 2004
A lot of people debate the subject, but as someone who actually HAS one, I'll tell you that its not really a noticeably boost in hp, not that many bolt-ons are, but I also added Subframe connectors at the same time so that added a little weight and probably minimized gain a little. My car is definately a little bit smoother now, however, and I'd guess there is a LITTLE gain, at least based on my dyno numbers but who knows. I put down ~170whp @ 5300* with just the Aluminum D/S, K&N Filter, and Duals, so I would think that is significantly better than your typical Filter and Exhaust V6. So there's my experience. Would I do it again? Maybe, but I'd probably put it into U/D pulleys first since that would be a similarly priced mod. But it DID do something, as opposed to what some may say, I just wouldn't say its the BEST mod out there by any means.
mustangmat99
167
  • Mar 1, 2004
yea i know its not the best but with all im getting already to boost my h.p, i was just wondering if a lightweight one would transfer the power to the wheels any easier then the stock one, thanx though! ill see what otheres say as well
3,287
24
69
Broke
Mar 1, 2004
  • Mar 1, 2004
You wont see much difference.
kylew5
142
Copperas Cove, Texas
Mar 1, 2004
  • Mar 1, 2004
The aluminum D/S is my latest modification and I'll be honest, the gains from that alone won't be all that incredible. Frankly, the chances of you feeling any differences in horses is low but technically it will help you a little down low.
Your ride will be a little smoother, but I wouldn't advise doing this mod until you do a rear-end and t-lok swap. That's what I did.
C
Captain_Ron
25
Exeter, MO
Mar 2, 2004
  • Mar 2, 2004
The main thing about the aluminum driveshaft is that it is a lighter unit that is perfectly balanced. When you change gear ratios to say 3.73's or greater you get noticeable gear whine. The balanced drive shaft helps eliminate that whine and cut down on the rotaing mass of your stock driveshaft to free up some rpms. You don't however gain any horsepower by adding the aluminum piece. The down side to swiching to a lighter weight driveshaft or flywheel is that cutting down on rotating mass also cuts down on torque power. Not much but a little. Everything you do the your vechicle has give or take properties.
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
D
2008 Bullitt take-off parts (muffs & shaft)... recycle or resell?
  • D-Tex
  • Nov 3, 2024
  • What is it Worth?!?!?
What is it Worth?!?!? Nov 3, 2024
D-Tex
D
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
