Posi trac is the GM name. Ford calls it a limited slip differential. Same part, same function, different company, so a different name. Both should turn the wheels the same direction when you rotate 1 wheel.
Having driven and watch my dad's 06 GT (automatic), it sometimes doesn't act like it has a limited slip differential. I suspect it is very soft and allows slippage easily.
I'll be darned too!When I bought the car new I thought for sure that being a GT,it was standard.The ordering guide provided no indication
that I had to order it separetly therefore I thought it was standard.It
was only recently that I read something that made me go look.So I
guess I'll have to shell out a few more bucks.Thanks again
Guys...a limited slip diff. does turn the wheels in the opposite direction when the car is in the air like that, full posi trac is when they turn in the same direction.
If you have a limited slip that isn't completely toast, it will spin the tires in the same direction. If not or the limited slip is completely toast, it will spin the other wheel the opposite direction.A limited slip will spin in the opposite direction or else it would be a full locked rear and would not be able to turn, that's why its named "limited slip" to allow you to turn around corners and curves in the road allowing for smaller turning diameter between inside and outside wheels.
