If the car is in gear the wheels will spin in the opposite direction.
Huh?
Huh?![]()
I gotcha....I thought he was implying that when the vehicle was running and in gear that the wheels would turn in different directions.If the driveshaft can not turn, because either the car is in gear or the transmission in park, then turning one wheel will spin the other wheel in the opposite direction. You have to overcome the grip of the limited slip differential though, which is around 100 ft*lbs before that will happen. That's only when the driveshaft is locked and won't rotate.
floor it and look at the marks left(traction control off)![]()
Every V8 Mustang since 1985 has had a Traction-Lok 8.8" differential, regardless of transmission or any other variable. My '07 GT Automatic came standard with the Traction-Lok, as did all S197 GT's. You likely have a defective differential, or don't know how a Traction-Lok axle should feel/behave.
With every truck I have owned, if I pull into traffic making a right turn on a wet road, the inside tire always spins. This tire is obviously the one with the least amount of traction. I thought limited slip transferred torque to the wheel with the most amount of traction which should prevent this from happening. This is one area I have never heard consistent information on.
Greg
Brian,
If I go to the Ford website and build a new 2009 Mustang, there is an exterior option called a 3.55 limited slip axle ratio for $252. So if the car has some sort of limited or locking differential standard, how is this different and is it needed?
Greg
in 2007 the stock diff ratio was 3.31 and you could pay a bit for the 3.55 upgrade
If that is all it is I can just upgrade to a 3.55 at a later date. Anyone know if the numerical ratio is separate from the limited slip unit? Meaning would I only have to buy the different gear set or buy a new limited slip unit as well?
Greg
...but he will have to take it somewhere to have the two pressed apart.The ring and pinion gears are separate from the LSD. You do not have to buy a new t-lock.
they are bolted together, but you do need to press on the new bearings.
I too was under the impression that a limited slip diff would spin the opposite tire in the same direction with the car elevated.The car was in park at the time so maybe that made the difference.The body tag reads axle CG which I have been told indicates a traction-lok.My confusion was compounded by the fact that Ford's own 07 factory sales brochure states that traction-lok is standard on all GT deluxe and GT premium models,but in parenthesis it further states that it is optional on automatics....go figure.Thanks for the input.
Greg
Greg, most of us have changed the gears. The actual limited slip differential does not have to be changed, so you can reuse it with any gear ratio supported by the 8.8" rearend. For example, I swapped my 3.31's out for 4.10's.
Your question is valid, Greg, as there have been some rearends which required a different differential carrier depending on the gears being used. For example, I used to own a 1968 Pontiac GTO for many years. It came with 3.23 gears housed in a "3 series" carrier that was used for 3.08, 3.23, 3.55, and 3.73 gearing. I later switched to 3.90 gears for drag racing, but they required using a different "4 series" carrier which Pontiac used for 3.90, 4.11, 4.30, and 4.56 gears. Then, I switched to 2.56 highway gears for awhile when the car became a daily driver, but I had to get a completely seperate "2 series" carrier which Pontiac used for their 2.56 and 2.73 gearsets. It was a big hassle, so I'm quite pleased that Ford does not put us through the extra effort!
