Line Lock install help
Jason5.0
30
Saugus, Ma
ok.. so i bought a line lock from summit and the summit install kit (should both be here by monday) but i think i may have a problem, the line lock only has one inlet and one outlet, but.. my mustang has 2 lines coming from the master cylinder to the front brakes, one line comes from the bottom of the cylinder and goes directly to the drivers side caliper, the other line comes from the side of the master cylinder and goes to the brake dist block and then to the pass side wheel, how do i make this work? any one ever do this? help me out. thanks
The line leading to the back brakes directly from the master cylinder gets removed and that port gets blocked off. The distribution block now becomes rear/front lines (1 line each) instead of left/right front brake lines , the single line coming out of the dist block that now is the front brake lines goes to the line lock solonoid and now becomes left/right front brakes from there.
The kit will come with diagrams and such.
