Line Lock Kit??? where to buy it??
it will work with abs...they just had to put that it wont to cover their asses in case someone screws it up. it will be fine as long as you use it properly..."technically" none will work with abs but people do it all the time
E9_95_GT said:
what kit did you buy?
I bought the TCI anti-roll kit. I bought the installation kit as well which was totally USELESS. Except from one line that I needed. Should of bought it at a local shop. You need a flaring tool to "double-flare" the lines. Ours is single flare.You can see where I hooked mine up. Works perfectly. I dont like that loop we did with the line but I was in a real rush. Never got back to fix it. My original thread for my line-lock install
