little confused on using a jumper to check engine codes...
killer5.0
5 Year Member
Oct 8, 2009
725
83
59
i have a MIL light on my car (93) and i want to check for codes...the diagram shows multiple jumper wire it looks like but dont i just need to run a power jumper to the self diagnostic harness? or do i need to hook up a few connections? thanks
Well technically you want to get three code 11's.
Code 11, followed by a 2nd code 11...when you get the the pause, then you need to start the engine. The revs should climb up to around 2000RPM, come down and then the light will blink once. This is your signal to blip the throttle. After the blip, the engine running codes will be displayed.
ok...installed jumper and started car...blink, blink...quick pause...blink,blink...engine rose to almost 2000rpm...went down (almost stalled) back up and down (almost stalled again) back up...slowly came down to 1000rpm blink, blink, 2-3sec pause blink...2-3sec pause..blink blink...2-3 sec pause blink...and that was it.
okay..yeah its pretty chilly here today (40) guess ill have to let it warm up then give her a shot...prob wont be able to until tomorrow or monday now but i will post up results...thanks
could i have just done something...i let the car idle for like 10 min...temp was right about 160 shut it off but had the key in the on position...inserted the paper clip...went to start the car...idle up to 2k then stalled...keeps stalling unless i keep my foot on the gas slightly...i am low on fuel at the moment (on E) but i dont think thats an issue since it was idling fine do you? i have to go get some fuel tomorrow.
